Tamiya TB-Evolution IV
#2026
Re: Re: Re: Look at my evo 4
Originally posted by Superdate
Thanks man, that is the one i saw before, hehe, just cant remember it. how do you find the alum cup?
It'll be there
It says he's out of stock, but email Steve. He'll give you the most up to date information
vic
#2027
are there any other parts very easy to broke? i am gonna order from rainbow, can someone pls give me some ideas/? then i can get some more spares
#2028
buy a lightened propeller shaft and aluminum input shafts to go with your alum drive cups. rainbow has them and they are not expensive.
#2029
Originally posted by cooliomojo-CEBU
buy alot of bevel gears. if you use a one way, chances are you will chew-up some bevel gears. some tips for the car.... CA the screw that holds the bevel gears so that it will not come loose.
car is hold up great. buy the necessary hop ups and the car should be bullet proof for stock and even 19T. not sure about mod. i dont run that too chicken.
cooliomojo-cebu im close to that "aggressive" set up you wanted. -1.5 camber front, -0.5 camber rear is waaaay too aggressive. dont try it at home!
ill post on the TAOB thread once i finalize it at another track
#2030
Chris... good practice today (where were you? jas kidding!)!!! Although I did felt bad about your 2nd burnt KO ESC. Make it a 3rd and you'll be in the record books.
Ran the Evo4 today at Tamiya and it was hooked up in cold weather with take off 27s. I did feel a bit of torque steer... but it wasn't consistent and sometimes just went away. The car was pretty much stable specially in the infield, but the 415(Speedtech Steve's) I was running with was a tad bit faster on the straights.
#2031
#2032
Originally posted by Hebiki
November OC Circuit Race. (Behind the La Mirada library, second sunday of every month)
EvoIV - Ian Aquino
Pro4 - Jasper David
CGM - Paul Dabao
TRF415 - Me
TRF414SS - Kevin Cole and Terence Cole
Barracuda R3 - Bryon Kaholi
X-Ray T1FK? - Howard Hudson
EvoIV - Ian Aquino
Pro4 - Jasper David
CGM - Paul Dabao
TRF415 - Me
#2033
#2034
Originally posted by hierog
take a look at www.speedtechrc.com. you can buy the Tamiya cup or the Square cup. The Tamiya cup is a bunch cheaper, and both are of the same quality. I bought the Square one because it came out first!
The tamiya cup should run you about $7 USD
vic
vic
#2037
Re: Clear Covers
#2039
now if only he could get the clear pink covers...
#2040
I noticed that Hebiki didn't have the support posts for the center of chassis, to join the plastic top and bottom decks on. I believe that they come with the clear tamiya plastic stuff too. Can anybody confirm that??
also, what are the ball ends used there?? I mean the grey cups that sit on the balls.
Also, what turnbuckles are used there too. I really wanna get some more of this blue on my car!!
