Schumacher Corner
Last week I had one my front left shock leak all its oil in a race, I don't know what caused it as I didn't hit anything - they've gone a couple of months without a rebuild though. I've just taken the shock apart and the top black bladder has split.
As I can't open PDF's at the moment, and I haven't got a manual, are the bladders available on their own or is it just as part of the Race Shock Seal Rebuild Pack (U2999)?
Or are there any other bladders that fit?
I believe the much more bladders work in a pinch.
Regional Moderator
R/C Tech Elite Member
Thanks guys, I'll get the rebuild pack and change the o-ring on each while I'm at it.
On a similar note, has anyone had the gold colouring turn silver as the shock shaft enters the unit?
Regional Moderator
I know I've had a couple different cars with this type of coating on the shock shafts, but no matter where I ran the car (indoors/outdoors) I've never had the coating wear off.
I had the same thing happen to my original shock shafts, I changed them out and I have not ever had a problem since.
i think our upper shock mount is one of the best in the industry. it allows you to take out any slop a standard ball joint would have by how much you tighten the locknut. it's little things like this, that aren't on a setup sheet, that people don't always know how to duplicate.
-- brandon lattimer --
Whoa.
Super Moderator
Its a term they use in chess.
