Schumacher Corner
Is the antenna wire touching the chassis?
My GT7 was putting out straight batt voltage to the reciever. I think it has injured both of my recievers. The thing that is concerning me now is that i tried a known working setup with just my transmitter and had problems. So I think I'll probably replace all the in car stuff with new and try it with my transmtter. If that doesn't work, new Tx time.
thats weird I used my original Futuba HRS reciever and then bought the DSM system and had no problems with it either.. maybe its your reciever I guess.
Could be the Spektrum stuff, maybe send it back to Spektrum and get it updated. If the GT7 is the problem you can send it into novak and get it repaired, they have excellent customer service.
Is it an M8? I had a similar problem with mine a couple years back and sent it in for a recalibration. Fixed it right up. PW's right. I never had one glitch when I ran a 27 MHz Novak Switch and Xxtra Rx. In fact, last year at the Reedy race that's what I switched to to get rid of the dreaded Tamiya glitch a lot of guys have there running 75 MHz. I know PW doesn't like them, but I love the Spectrum. I had one of the first ones and still to this day, not one problem. (Knock on wood )
Jack was running my car with all my electronics except for his transmitter and someone elses spektrum module for the M8. I've never had any glitches at that track so it must be either the transmitter or the module.
Originally Posted by Jack Smash
I ran a loner MI2 with spektrum this weekend with my transmitter. Qualified 5th in 19turn and had the 3rd fastest single lap at a track I have never run at but had to pull off on the first lap of the main, still glitching.
I guess I'll just start throwing money at it till I get it straightened out.
If you were using your mototrs then I'd have to say there's your problem.
Hey does anyone have a good set up for stock asphalt. here a photo of our track it changes weekly but this is what it looks like most of time with some variance. thanks in advance
http://www.irocc.ca/stories/race12-5.jpg
I'd start with P-Dubs Nats setup. Seems to be the ticket almost anywhere asphalt. Maybe try a one-way if the layout is open like in that pic.
Heres a link to P-dubs setup.
http://www.gearchart.com/index.cfm?f...&showheader=No
im getting my titanium dog bones 2 day an im getting a heavy duty one front one way next week
i'm planning on trying a both a spool and a onw way. very soon. thanks for the info.
Hi Guys,
I just got my alloy rear pulley and was wondering, which way do the fence's go on, I know the instructions say the side that face's away from the spur gear has the step facing out, but what about the side facing the spur, in the pic it's flat, but that is the moulded one, and the fence doesn't snap on that way, where as if I put it so the step is out, it has to click in and stays on better. And it's wide enough for the rear belt with the step out?
Iain
Iain
Originally Posted by Iain
Hi Guys,
Iain
Iain
talking of pullys
if i turn my spur gear and hold the pully i can turn the spur alot (not quite a qutter) befor it gets a "grip" what do i need to stop this?? if i get the alloy pully will that solve the problem?
thanks bob
thanks bob
