Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 06-15-2007, 07:20 PM
  #20206
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by aus jd 2703
hey how do u guys get your wires coming out of ur esc to be horozontal in stead of vertical like what its normally like? i wanna try it to see if i can thread them under the top deck?
cheers
If you can, just unsolder them from the poles placing them vertical and re-solder them down horizontal. Most all high end ESC's are able to do this..
Randy Caster is offline
Old 06-15-2007, 07:23 PM
  #20207
Originally Posted by jimmy..maddison
yoyoyo Randy, look forward to catching up with you at vegas!!
hows things with the car , what did you use to dye you white plastic parts??
thanks jimmy
It's on at Vegas this year, I'll have a lot of practice before the race, so I wont look like such a novise lol.
Use some Rit clothes dye, boil it in water and dunk the parts in for a few minutes until you get the color you want.
Old 06-15-2007, 07:45 PM
  #20208
ok cheers what are the best ball cups? mine are pretty sloppy so was gonna redo the whole car?
cheers,
aus jd 2703 is offline
Old 06-15-2007, 09:08 PM
  #20209
reilly's Avatar
Stephen,
Yeah you better believe it, I thinks it's Cleveland for me this year.
My cousin is getting married in AZ and eating up most of the vacation time. LOL
Have been running outside right now.. very impressed How do you like your car so far?
James
reilly is offline
Old 06-15-2007, 10:02 PM
  #20210
justin lessard's Avatar
cheers,
RPM ballcups
justin lessard is offline
Old 06-15-2007, 11:04 PM
  #20211
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I looked online and on the manual and was unable to find a part number for the 96t 64p spur gear. Does anyone have it handy?
andrewdoherty is offline
Old 06-16-2007, 12:08 AM
  #20212
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default Andrew
the 96 hasn't been posted in the US or UK site.
you might have to call Schui USA.
i ordered a few on Thurs and forgot to write the part number down.
sorry dude.
June UK Schui news letter:
http://www.racing-cars.com/images/pdf/schumacher_june_newsletter_l.pdf"]http://www.racing-cars.com/images/pdf/schumacher_june_newsletter_l.pdf"]http://www.racing-cars.com/images/pdf/schumacher_june_newsletter_l.pdf
page 3 ...also has the pic of the new stiff and flex top decks
olhipster1 is offline
Old 06-16-2007, 09:47 AM
  #20213
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
part # is u3248
Marcos.J is offline
Old 06-16-2007, 11:14 AM
  #20214
randy you have pm
jimmy..maddison is offline
Old 06-16-2007, 03:49 PM
  #20215
cheers,
Even though they have slop, they dont pop off in a crash which is all that matters to me. Slop in the ballcups just makes the car easier to drive.
Old 06-16-2007, 07:07 PM
  #20216
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Advice from Master Schumacher Mi3 driver, Adrian Martinez, to use a plastic bag and place it on the ballstud, and then press the ballcup into the ballstud, and the it cuts a perfect cutout of the plastic bag and removes the slop. The Schumacher ballcups are exremely durable and very tough...better than RPM ballcups...if you have play, all you need to do is follow AdrianM's advice and you'll easily fix the "problem".
yyhayyim is offline
Old 06-16-2007, 08:14 PM
  #20217
Very true, I guess I plain forgot about that trick, havent done it in 5 or 6 years..
Old 06-16-2007, 09:39 PM
  #20218
JayBee's Avatar
Trader Rating: 31 (100%+)
Yep sure does. I tried it and the 'trick' should be patented
On another note, finally got to run the car today and Weylin's set-up worked pretty good as my base set-up but with several progressive changes I made, the car is coming along nicely PW expect a phone call Monday , those blasted CVD pins got the best of my day 3 of 'em! It's all good though, Schumacher to the rescue
Final verdict- Awesome piece of toy car!
JayBee is offline
Old 06-16-2007, 11:36 PM
  #20219
Is Schumaker USA replacing cvds ( I also broke 2 front cvds)I got my car from Steve at Speedtech but I am in Australia
Barger is offline
Old 06-17-2007, 01:23 AM
  #20220
Default Toe in
Hi
How does one get less toe in on the Mi2-EC Foam spec kit, i am needing to get between 0 and 1 degree of rear toe in.
MoonTrap is offline
