Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 05-27-2007, 04:55 PM
  #19606
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by Fred Perkins
You have room to talk.
Marcos.J is offline
Old 05-27-2007, 04:56 PM
  #19607
Super Moderator
Marcos.J's Avatar
Originally Posted by AdrianM
yyhayyim - The Mi3 is one of the toughtest cars on the market. Weylin and Alex must have really smacked the hell out of their cars (or someone else hit them HARD) if they broke.
it is though!!! I tested that out today!!
Marcos.J is offline
Old 05-27-2007, 04:57 PM
  #19608
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
AdrianM- after my first run today, I have post checked my car, and it seems something has given in the front axles/bones...looks like the pins and bones...I barely tapped a few corners over all with traffic- no hard crashes...seems weird. Will need new pins and bones...What happened? Will Schumacher come out with Ti pins, or strong steel ones?
yyhayyim is offline
Old 05-27-2007, 04:59 PM
  #19609
yyhayyim's Avatar
Originally Posted by dawgmeat
dude I wouldn't put to much stock into who winnin' Reedy, Factory TC4 won 2 years ago it last year still didn't make it the best car. PW is facing the best of the best so their no room for error, when Weylion Rose starts at 2 then ends up 8-10 thats a peel fest
Come back Teemu Leino!!!
yyhayyim is offline
Old 05-27-2007, 05:01 PM
  #19610
yyhayyim's Avatar
Talking
MJ- where is your test report? How is it compared to the Type R or Cyclone you had...
I hope Schumacher has axles and pins in stock...
yyhayyim is offline
Old 05-27-2007, 05:04 PM
  #19611
yyhayyim's Avatar
Talking
Originally Posted by Charles Godwin
Try and keep with the servo arm. I've tried servo savers in the past and i've had trouble with them not staying centred after small taps. Check the chassis tweak, see if the chassis is flat or any other settings are out. There might be binding somewhere in the steering. Maybe in the driveshafts, i had to rebuild one of mine before i installed it because it was binding.
Charles: about the servo arm...if I do use it, in the event of a hard crash, will the arm strip, or the servo get damaged?
yyhayyim is offline
Old 05-27-2007, 05:05 PM
  #19612
Regional Moderator
Darkseid's Avatar
Someone mentioned the servo saver earlier. I just realized that this was the first time I've ever driven a TC without a servo saver.
Funny thing is, this was one of my biggest concerns before I got the car, but it didn't cross my mind all day , I just drove the car. I wish I could just forget about the universal pin issue and just drive. I've been told that I'm stressing over nothing, especially since I'm just running at 13.5 speeds. But in every corner, past every board, it was on my mind.
Not the cars fault of course, just that with all I've read about the pins, I couldn't get it out of my head.
Picking up an extra set of universals and giving a diff a try should ease my nerves. And let me just drive worry free.
By the way, how does Schumacher sell the universals? As a whole, or can you just pick up the dog bone section?
Darkseid is offline
Old 05-27-2007, 05:09 PM
  #19613
rcshark's Avatar
tuff cars are for the ones that cant drive the well design ones!!!!
rcshark is offline
Old 05-27-2007, 05:10 PM
  #19614
dawgmeat's Avatar
if you break 1 it will be replaced with the upgraded version and the next batch of kits will have them
dawgmeat is offline
Old 05-27-2007, 05:13 PM
  #19615
Regional Moderator
Darkseid's Avatar
Oh, I did forget to mention that I did have a minor issue with one of my front universals.
The grub screw holding the pin in kept backing out. Lucky for me, I had grooved the pin, so even though the screw was loose (VERY loose the second time) the pin couldn't fall out.
I had to pull that corner of the car apart a couple times. So that last time, I re-thread locked the grub screw and tightened it a little harder this time.(didn't want to over tighten it as I believe people have had problems with their EC's by doing this)
So my recommendation to people is to groove the pins. Its a simple procedure that can save you a broken universal.
Darkseid is offline
Old 05-27-2007, 05:24 PM
  #19616
JayBee's Avatar
Trader Rating: 31 (100%+)
NIICE ONE!!!
JayBee is offline
Old 05-27-2007, 05:32 PM
  #19617
Super Moderator
Marcos.J's Avatar
it was really good the type r in my opinion can carry more corner speed
as for axles i had no problem at all with them
Marcos.J is offline
Old 05-27-2007, 07:02 PM
  #19618
Trader Rating: 264 (100%+)
All I can say it that if you guys are breaking this much then you must be taking some really hard hits! My car went air born and tumbled end over end for 10ft! Not a single broken part! I drove away and finished the heat.
Schumacher has always been known for its durability and when there is a problem they always take care of it!
Fred Perkins is offline
Old 05-27-2007, 07:10 PM
  #19619
STLNLST's Avatar
Trader Rating: 32 (100%+)
TC5 it looks like a very tough car, which is nice...I am not happy with t he Mi3 results at the reedy. It seems Alex broke a few times, and PW had some good finishes, but seemed inconsistent- 26th overall...maybe he broke, too...but Randy Caster and Weilyn Rose did very well.
TOASTY!!!!!!
STLNLST is offline
Old 05-27-2007, 07:46 PM
  #19620
alecladanga's Avatar
Hi Guys
Just like to ask if soembody from Schumacher knows when the Mi3 will reach Asia, particularly the Philippines?
Thanks in advance.
alecladanga is offline
