Xray T1
#3121
Originally posted by rayhuang
AWSOME!!! Cannot wait to see you guys again!!!
You can run anything you want. We have Corally "jack the Gripper" for sale all the time if you want to go odorless!! I am sure MO's got some left too from his Nats domination tour!!!
Oh-yeah-Paragon is of course the favorite sauce, but were trying to get as many people to switch as possible.
Bring a table and chair!!! if you need one-I'll bring in a couple fr you guys. Just let me know so I can bring em Sunday.
#3122
Corally TC2 "Gripper"
Glad you asked!!
It is almost exactly the same on track performance, but a little bit diferent off track. YOu need to put it on a bit longer-though it soaks in great!!! Wipe off just before racing and scrub tires into track very well before racing if not car will skate around for a lap.
It lasts a really long time-thats noticeable in 12th scale's 8-minute race. Also noitceable in Sedan where I can practice, make changes and keep going out and grip level stays very consistent for a good 20 minutes.
After 24 to 36 hours after race-tires Feel and Smell like they never had traction compound on them!!!
I think that may be a big advantage over Paragon-which keps softening the tire if you dont clean them after every race. Also-all that cleaning with motor spray and lighter fluid makes the glue soften and you are more susceptible to chunking.
But the biggest adavantage is I can give my daughter a big HUG when I get home and start playing-not "Hello-sorry gotta take a 20 minte shower and try and breath again". And get the "llok" from tired Mom!!
#3123
Re: Corally TC2 "Gripper"
Glad you asked!!
Glad you asked!!
#3126
Re: Question about asembly
Originally posted by pucho
Im putting an evo2 together for a friend. so far it's everithing is going well. Now Im putting on the bumper it states that the body post shoud extend down through the foam bumper but thins thing seams to be too thick. Am I supose to just squeese it unlitt it fits? or does it need to be trimed? Also what pistons are you guys using?
#3127
Re: Re: Question about asembly
Originally posted by PW
Hey pucho....Is that Alex's car your building?
#3128
Originally posted by c-lyon
pucho, I had the same problem with my first T1. The foam was 3/16" thicker than that on my second T1. It was 15/16" compared to 12/16". I merely cut out the area covered by the top brace ; problem solved.
#3129
What I did with the foam was added shims where the bumper brace and the bulkhead meet. It solved the problem of the brace being bent from the foam. A new problem arose though. The problem was that the brace was raise high enough where the brace and bulkhead were not flush. This setup may potentially cause a break on the brace, or separate the laminated graphite should the car crash into something.
#3130
Silicone Oil viscocity
Guys, I need your input based on your experience with the shock oils. I've noticed that the Evo2 seems sensitive to the change in shock oil viscosity. I ran 3 fixed piston with 40wt AE - white springs all around. Yesterday, I switched to 40wt Team Orion oil. The change was quite dramatic, the car tended to bodyroll thru corners.
And I happened to have a little AE oil left in the bottle, and I took a time to make some comparation with the Orion. I think Orion oil is thinner than AE's. Or could Orion oil easily lose its viscosity due to the weather changes ?
#3132
Redsand: There is no standard in viscosity of the shock oils. 40 wt lost and AE are different. This stuff is not SAE certified like automotive oils. Iuse X-Ray in my X-Ray and AE in my pan cars. Makes life easier.
#3133
#3134
Re: RCI tell me about your C-hub setup
Originally posted by RedBullFiXX
I picked up the composite C-hub kit at So-Cal today. The kit has 3deg(med) front blocks, but I also picked up the 6deg (med) set.
I know you have the aluminium kit, just curious how do you have yours setup ?
I am running the stock setup for my composite c-hub car for stock racing. For 19T, I'm running the aluminum c-hubs with 6deg blocks, the rest is stock.
I see you couldn't resist getting back to the "real car", not that toy you've been tinkering with.
#3135
Dave
Now don't get confused running two different cars like I did with the F201.
