Like Tree12Likes
Old 04-05-2010, 07:34 PM   #3691
TEM
TEM's Avatar
Originally Posted by geubes View Post
Hi guys.
Ran the Beta again on sunday, and it was really good. The only thing that let it down was my rubbish tyre prep and driving.
heres a vid from one of the finals:
http://www.youtube.com/watch?v=smv7OMO7pLA
im sat pole in this race, using schumacher with a SP gt2.0 with the supercharger. The guy behind me was using a Tekin, we were both using same motors. Annoyingly i could have TQ'd the meeting if i didnt role it in qualifying - that would have been something to brag about to the tekin boys
good work SP guys
Hows about sharing your settings, FDR, motor timing, etc.. thanks!
TEM doesn't advertise for free! Does anyone else notice that a LOT of companies are not even packaging decals with their products?
TEM is offline   Reply With Quote
Old 04-06-2010, 01:55 AM   #3692
Send a message via MSN to geubes
settings were:
Duo2 13.5 with 12 degrees advancement on endbell
FDR: 6.96 (89 spur, 23 pinion, 1.8 internal ratio)
Motor was coming off around 65-75 degrees C after 5 minutes.
software used: 318
settings:
DRRS: 7
ATMS: 5
12: 7
13: 1
14: 3
15: 5
Next thing i want to play with is increasing the RPM delay and removing motor-can timing to reduce the temps a little.
I tried setting DRRS to 8 eariler in the day (when it was cooler) and it increase motor temps but not lap times - so taking it back to 7 made the motor cooler but no slower.
I also tried reducing 14 to setting 2 (0.1 second delay) but it made the car harder to drive onto the straight and on the infield. it also increased motor temps due to the low rpm delay.
ideally ide like to keep the time delay as low as possible (off if preferable) and go on RPM delay. it appears to wait till full throttle before engaging on 318 - but if someone could confirm that, it would be really useful
definitely more testing required. ive now run it 3 times and its getting better each time, but theres still lots to test on it.
next step is again rpm and fdr changes to find that sweet spot... im hoping that when i find the sweet spot for the motor / track combo, it should be fairly similar on other tracks - with a few minor adjustments to delays.
geubes is offline   Reply With Quote
Old 04-06-2010, 02:45 AM   #3693
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by hacker View Post
Hi, is there a known problem with version 3 motors.
been using one for 2 days, and it suddenly went into 540 silver can speeds. Removed a shim on the sensors side trick, still no go. Another 2 guys are having cogging issues. Ran really conservative settings and never overheated. Changed sensor wire, dont know what else to do! Might have a crap on it latter
Send it in...
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 04-06-2010, 05:03 AM   #3694
defcone's Avatar
Trader Rating: 15 (100%+)
Are these people with 318 software team drivers?
defcone is offline   Reply With Quote
Old 04-06-2010, 05:34 AM   #3695
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
We are actually testing a different software as far as I know
Old 04-06-2010, 07:42 AM   #3696
Originally Posted by oblix View Post
I have a gt v2 plus a 17.5t v3 with 231 stock sw,our track is medium sized about 15 sec a lap in 17.5 straight about +/- 45meters in field medium tech chassic schumi 3.5 we run foam in SA.Need help with settings plus roll out
as soon as you talk about foam and asphalt I think your mails gets ignored because the guys run rubber tyres or carpet and on foam tyres. I suggest you go back and read from about pg230 for advice. There is a lot of useful information. Razzor has been very helpful wrt technical advice, a big thanks to him.
Pilotloots is offline   Reply With Quote
Old 04-06-2010, 09:27 AM   #3697
adri-13's Avatar
i have tested this week-end the Speed passion 2.1 software with a speed passion V3 10.5 . I have drived with 5.1 in ratio and the timing at 26. On a run of 7 minutes the motor was in 80 but it's more fast than the soft of the SP 2.0
Sorry for my English, i'm french
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 04-06-2010, 11:09 AM   #3698
altreyx's Avatar
Original firmware or the beta one?
Thank you
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 04-06-2010, 11:13 AM   #3699
adri-13's Avatar
it's the original firmware ( the 110 )
PETITrc driver
www.PETITRC.com
Old 04-06-2010, 11:44 AM   #3700
altreyx's Avatar
wow... i use fdr 7,1 DMTS at 5 (15) and DRRS at 6 on a circuit with a 25m of stright and rest is medium speed (at the end is a medium tech track).
But i never had the motor over 55C (SP v3 10,5) and the esc over 22C
For me you are using a little bit too much AMTS value...i suggest you to start with something more around at 15 and reduce a little bit your FDR (may be start at about 7,0 but depend on your track size)
Forgot to say i use the endbell timing over the motor a little bit less than +10 (i can say at about +8)
Bye
Orca-Gm120
Reedy-Lrp
Helios EX10
Old 04-06-2010, 01:35 PM   #3701
settings were:
software used: 318
settings:
DRRS: 7
ATMS: 5
12: 7
13: 1
14: 3
15: 5
What is "software 318" ????
If it's the next thing on from 230/231 ........ that is being tested by team drivers only ........... what relevance is this post to us mere mortals who only have access to 230/231 ??????
When might we see a "proper" official software down load available from Speed Passion (on their website)??
This all seems to be dragging on a bit now!
Mi4LP / Speed Passion GT Pro V 2.1 Pro Stock / GM 10.5 Pro Stock
Cat SX / Speed Passion GT Pro V 2.0 / Speed Passion 6.5 V2
Mugen MBX6T / Ninja BO1A
baldman666 is offline   Reply With Quote
Old 04-06-2010, 02:00 PM   #3702
Super Moderator
charlie_b's Avatar
230/231 was released because it was deemed 'safe' for the user. 318 is still being tested by some of the drivers. Just because there is a newer version of a software doesn't mean it is safe for the end user...if you have read our previous posts, some of us have blown 3-4 motors testing new software. Im sure you wouldn't want to do that now would you?
Old 04-06-2010, 05:19 PM   #3703
mr crum's Avatar
Send a message via Yahoo to mr crum
it is probably a faulty sensor send it in with all ur info as specified per website and let the guys take a look at it
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 04-06-2010, 05:22 PM   #3704
mr crum's Avatar
Originally Posted by Marcos.J View Post
+1
Harold I will be at the track on saturday I have a couple of ideas I want to try out
i will try im having trouble with my truck so gotta get that issue figured out before i can play
TEAM B.R. RACING
Old 04-06-2010, 05:24 PM   #3705
mr crum's Avatar
Originally Posted by xrayal View Post
Kschu, crumb thank you. Is the midrange something that is being looked at? Other than that, 231 is 90% perfect for our smallish indoor cicuit. So pleased with my gt2.0 speedo. Thank you all at speedpassion.
And if you need testers this side of the pond........ lol.
your welcome al
TEAM B.R. RACING
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
