T.O.P. Racing "Photon" 1/10 EP Touring Car
#8207
.2mm
#8208
I remember reading that some say lighter arms give better traction. It has something to do about lighter arms make the suspension work better due to less weight. I could be wrong. I have them on my car and can't tell the difference.
#8209
I didn't get a chance to do back to back test, but the lighter arms have no flex at all, and the stock ones have a little bit, the lighter ones seem to make the car a little more responsive, but that can have a lot to do with your setup. Many of these changes can vary alot depending on what your car is doing.
#8210
Is anybody using the alloy camber link plate sets? Whats the benefit of running them?
Second is anyone using the alloy stearing blocks?
Thanks,
Joe Roach
This is my second year running carpet after a 21 year hiatus?
Thanks,
Joe Roach
#8212
Hello
My setup of the 5ş round of the National championship.
Top Qualifier and 6th place overall.
Best regards
Pedro silva
Best regards
Pedro silva
#8214
does anybody here is using ballast weight on their photon chassis? do you get more stable cause of the weight? what is the ideal weight do you guys run? thanks in advance for the info:
#8215
Top Narrow Chassis
Aluminum steering knuckles and rear hub carriers
KingHeadz bellcrank
Stock screws and turnbuckles.
Old Epic 40C 5000mah battery
Car just comes in at 1384 grams. Probably the closest I've ever been to minimum wt. requirement.
No use for any dead weight on chassis, I did swap the belt sides to mount all electrics as close to middle as possible and mounted battery as far out as possible. It's still heavy on one side just a little bit. But the car is so fast it's not noticeable at all.
#8217
today I try Alloy Steering blocks...little bit nervous...the Plastic one is better.
#8218
Photon wins the 2011 Germany Summerchamps in Hann.Münden
1st, 2nd, 9th in Modified
4th, 5th in 13.5
4th, 5th, 9th, 11th in 17.5
4th, 5th in 13.5
+ YouTube Video | |
