Talkin' with Josh Cyrul
#1862
Josh, our local track has moved and now has a carpet track under construction. The guy that is going to be setting up the track tried contacting you to get info on installation of the barriers. If you could, would you email me the info and I can forward the email. Include how you mounted (only velcro?), what material you used for the "bumpers" and how to fasten them, and any other trick/tops you have. I know you are a busy man, so if you can, thanks alot!
#1863
Thank you for your answers. One more.
The new sheet does not list how far back to put the rear arm. Your previous national sheet says max, with the 6mm box checked. Are we to place both spacers in front of the arm to move the arm back the maximum, or just place the 6mm spacer in front of the arm, with the smaller spacer behind.
#1864
Josh did you ever try the red spring setup you were on about at cleveland???? You know the one you wanted to try from yuour fuely car idea.
John
John
#1865
Originally posted by Josh Cyrul
kid - The camber is what gives you the traction in the corner when the car rolls - if you run less camber, then you are on more of the orange which will cause the car to push....
#1868
Rob - Go to www.cefx.net and the contact page and send me an e-mail....
Tom - They really messed up the set-up sheet I sent in...lol.. I used the max wheel base setting.
John - I tried it but it understeered too much into the corner - it had great on-throttle steering though. I tried it in the 2nd round of qualification at Cleveland but it was just too lazy through the chicanes....
kid - Thanks!!
Jamie - Thanks!! The site I guess was down but it's back up and running now. I don't have the set-up posted on the site as of yet but I will get to that soon.
Corey - I like the short links down. Faster, I don't know but it's what I prefered when I tested.....
kid - Thanks!!
#1869
Josh, I want to try out your Nats setup for 19T/foam, but can I do it to a "T" aside from the battery layout? I'm using a BMI 350 chassis. I assume that the 70wt/35wt oil you used is still Associated? Thanks in advanced! Tommy
#1870
Hey Josh:
Here's one that I was asked, and didn't know how to answer it. "How does the position, forward or back, and the angle of the shock effect handling?"
#1871
kid - Thanks!!
kid - Thanks!!
You said this in response to a question I asked earlier:
trackdesigner71 - We are testing the 1/12 oval car again. I built it back up today and as we are starting to run oval now at Halo I can test it to get it ready for this years Snowbirds. We won't be doing 1/10 cars though... More info on that one later...
Now does that mean that you picked up a new sponsor for racign 1/10 pan cars or does XRAY have something nice up their sleeve? Or is that a company secret...
#1872
kid - It is Asc oil and you can run the set-up with the batteries in the standard position instead of moved up like mine - you will loose some steering though....
Darryl - Moving the shocks forward or back changes the spring base (I don't know the technical term). Basically, while the roll would remain the same, if you moved the front shocks .5" farther forward, you would reduce front dive as the pitch of the chassis would have a greater effect on the shock travel. That's why 2wd off-road cars have the shocks in front of the rear arms as they want a shorter spring base to gain more rear traction - more transfer under acceleration. You wouldn't get that if the shocks were on the back side of the a-arms like a TC...... Other wise, you always want the shocks to be 90 degrees to the a-arms - including if you are running anti-squat or anti-dive.....
trackdesigner71 - Actually, I will be using a Custom Works 1/10 oval car at this years Snowbirds. This way CEFX can focus our effort on the 1/12 cars and bodies for the 2005 season.
#1873
Darryl - ...... Other wise, you always want the shocks to be 90 degrees to the a-arms - including if you are running anti-squat or anti-dive.....
Randy - Dremel the rear a-arm and then re-drill the hole so the threads are deep enough.
#1874
