TRF414M, 404x, 414, 414X
#2776
i just finished playing initial d today
i lost 4-5 times and got up to the 8th guy... mr2 dude
#2777
Got some stupid questions again!
Hi.
i was wondering what's considered too hot for a 27turn johnson stock motor? I was running according to the instructions spur 120 and pinion 40 and the car is so slow, my tao2 kicks its ass in a straight line! running with this gear ratio, the motor is still very cold and barely warms up after a whole pack of battery. I now run it with a 112 spur and 46 pinion, it's fast now but the motor gets so hot it can burn if you leave your finger there for about 10 seconds. is this gear ratio WAY too much for the motor to handle? how can i squeeze even more speed from my car while still having everything reliable and not burn up? what's a recommended spur and pinion size for max top speed given that i must run a 27t johnson motor?
thanks for your help!
#2778
Re: Got some stupid questions again!
Originally posted by poop
Hi.
Hi.
Calvin: Common keep on practising got those pics for you byu the way.
#2780
FUK_WRX:
so should i gear it back to the factory recommendation of 40 pinion? then how could i squeeze more top speed out of my car?
cheers mate.
FUK_WRX:
cheers mate.
Before when i used my car with a johnson in 540 class, i switched to 48pitch gears. I geared my car 90TSpur and 35-40T Pinion. I started with a 35 and ended up using 40 in the end. It had sufficient top speed for that track layout. Anywayz let us know, im sure the other guys will be able to help you out also.
#2781
thanks for your info FUK_WRX
was wondering what the benefits are for changing to 48pitch apart from minimising the chance of stuck stones between the gears?
i'll give it a go 90T spur and 40T pinion and see how it performs. will this gearing overheat the johnson?
cheers mate, thanks for your help!
#2782
Re: thanks for your info FUK_WRX
#2784
what kind of temp should i be aiming for? hot/very hot/very, very hot/burning hot/3rd degree burns??
thanks mate.
thanks mate.
#2785
TRF Tool set question
Hello guys i was wondering if you know if the Red TRF tool set has more pieces than the blue one ?? I saw an auction in ebay for a Blue TRF tool set it contained 7 piece tool kit. But when i viewed the Tamiya web site it said that the red one contained 9 pieces ??
Can some one verify this for me ??
#2786
i CAN verify the red ones got 9 pieces with it yeah
2 positive drivers
turnbuckle tool
ride height gauge
3 hex drivers
2 nut drivers
hope i helped
Tarnjit
2 positive drivers
turnbuckle tool
ride height gauge
3 hex drivers
2 nut drivers
hope i helped
Tarnjit
#2787
johnson stockies with 4.8 or 4.5/4.6 FDR
test them out
test them out
#2788
just got my lighweight bulkheads in
yayyyyy ... they feel pretty light!
#2790
Re: TRF Tool set question
