TRF414M, 404x, 414, 414X
#2791
Re: Re: TRF Tool set question
Originally posted by TRF-Powered
I believe that the red tool kit comes with the turnbuckle wrench and the drop gauge, which the blue ones doens't come with (but is sold seperately)
#2792
nope.... they wont take forever to reach top end .... if u have a punchy pack of batts .......
will u fry the motor ??
answer is yes if u follow tru with 2-3 pack and hard driving ..
the coper will melt ... ever smelt burning copper??
#2793
Gearing...
What are you guys using for gearing. I been trying to use different spur and pinion combinations and it just doesn't feel right. 7.14?
27T stock and 19T
27T stock and 19T
#2794
7.14 ? Sounds undergeared to me. Last year with 17T I've used ratios between 7.2 (short indoor track) and 5 (loooong 1/8 track).
So with 19T and 27T, you should use ratios between 7 (19T indoors maybe) and 5 (27T outdoors) I believe for usual tracks.
#2795
#2796
I geared 5 with a 17T outdoors, but it was a really specific track, with a 80 m straight, better for 1/8 or even 1/5 scale cars. The fastest car geared 4.7, but I just did not have more than 45T pinion !!!
But with a 27T a gearing of 5 or less will be more common outdoors. I don't have a lot of experience with 27T, I stopped this class 10 yrs ago, but comparing to what I used with my 17T, 7.1 with a 19T seems really undergeared...
#2797
i know the 414 isnt very good with tire widths and stuff
i know that 24mm is the largest in the front
but how bout the rear could u guyz run 28mm in the rear?
#2798
got some more newb questions
I've started playing around with the spacers on the suspension blocks with my car by raising them with an extra 2mm with the little blue spacers front and rear. the car handles much better than the standard settings for me but i've noticed that the belt is scraping and has taken out around 1mm of the front suspension block!
how could i raise the block without the belt scraping it? I've tried raising the whole front bulk head by 2mm too, which cured the scraping problem but the belt gets really loose.
also, on the tamiya supplied set up sheets, what does C1, C2 for the front upright mean?
thanks for your help!
#2799
414M vs. Evo3 comparison
I gave my 414M a try yesterday, just to make a quick comparison. Running 19t carpet, surprisingly, it felt very similar to the Evo3. Lap times I guess would be about the same (couldn't compare since the track layout changed). I didn't feel a drastic loss of acceleration due to the belt drive. In stock class I feel that the Evo3 would have the edge because of the shaft drive. But in 19t and mod classes, the two cars are pretty similar.
In order to have the belt clear with a raised roll center you have to dremel the cut portion of the block a little bit.
#2801
get TB3 suspensio mounts, they are already raised by 2mm and it just works fine.
#2802
Re: 414M vs. Evo3 comparison
#2804
you can either run the evo 3 suspension blocks, or run the 414wcr block (if you able to get hold of it) as it has the cutout mod already done.
#2805
i thought tamiya are gonna win the reedy race but didnt.
if they cant win this how do they expect to win the worlds ifmar championship.
iam soooooooo upset.
