Tekin RS ESC sensored
#3541
#3542
#3543
THe revision history link there doesn't show anything newer than version 2.6 from may of 2008, but the download link should be the new version
Post back here with the version number you get, and if you're running XP or Vista.
Version 1.98 isn't what runs on your PC, it's the firmware that runs in the RS. When you selected 1.98 in the version list, did you then actually update the ESC, or just save the settings... when you Update the ESC, it goes through the four step process, if you didn't do that you didn't get 1.98 into the RS and still have the old firmware in it.
#3544
i have version 2.15 of hotwire when i push on help. I have version 194 in the hotwire. What is then different with version 2.6?
running xp
running xp
#3545
Thanks Trips, got it now, still getting used to the hotwire screen But like nitrobeast I noticed that once I select the 1s and apply the settings, unhook the hotwire then hook it back up that box is then not checked, Anyone else seeing this also?
chris
chris
#3546
After you hook the hotwire back up to the RS, try hitting the "read current" button and see what happens...
Also, can you check the version number of the hotwire software... hit the "Help" button on the initial screen before you plug the RS to the hotwire.
#3547
I'm assuming that your refering to the top box "current settings"; if so when I click on that the 1s box is still not checked. The version of the hotwire is 3.24. The interesting thing is that when I select the 1s box a little pop-up box comes up and says "voltage cuttoff has not been set set the voltage cuttoff defore driving". However I do have the cuttoff set at 2 in the esc.
#3548
The new Hotwire version that comes with firmware 1.98 is version 3.24, and it comes with the 1s LiPO cutoff.I really haven't had a chance to look at it yet.
#3549
i uninstalled it and installed the new hotwire version. It says tekin hotwire version 3.24 now and it has the 198 version as well. Curious what the difference is between the versions other then the 1S button
#3551
Trips
2.6 is an older version of the Hotwire software... real old. Version 2.9 was the version that came with 1.89 fiormware, and then Tekin did something kinda funny with the version numbering and 2.15 came with firmware 1.94.
#3552
Hi Rick... been a while.
If you go to http://www.teamtekin.com/hotwire.html and click on the "download" link you'll get the latest version... that's where I got it.
David
David
#3553
#3555
Randy,
This is a little off topic. I have all my Tekin ESCs (RS Pro, R1 Pro and R1) updated to the 198. I'm using the R1 in my Recoil with my own 7500Kv 4 pole micro motor and it's smoother then it was with the previous software version. Have you guys just added the 1S lipo and Reverse motor option or have you guys done anything with the start up as well? Also, my Recoil is much faster with the new version.
Regards.
Regards.
