Tekin RS ESC sensored
yea no more mucking around RS pro... thanks man
i have looked at the comparisons between the rs pro and the rs what i would like to know from a punch perspective is would the rs pro have more punch than an Rs?
i was told a while ago that more FET's = more power and more punch would this hold true seeing that the RS pro has twice the amount of FET's the Rs has?
any help would be appreciated
How do I wire a booster up for the RS Pro?
have the picture for a small lipo but would rather run a booster
I solder the + and - for the booster to the battery posts on the ESC, with a small switch in the + wire between the battery post and the booster. I then plug the booster into the receiver's Battery port. When I turn on the switch to the booster, the Rx comes on as does the RS. The ESC switch can be in either position, depending on whether or not you want the ESC LiPo Low Voltage Cutoff to function.
Any word on the new Hotwire software update?
but not the hotwire won't load on the laptop running vista
Are you trying the 32 bit or 64 bit installation (there are two)?
You can also right-click and choose "Run as Administrator" on the installer.
See if either of those suggestions work.
Also, Tekin posted a Vista installation video.
+ YouTube Video | |
32 Bit
Did the Admin option before I posted
212 was downloaded from Tekin site
Done what was suggested in the video
Tekin Rs Pro Fantom Apex or RevTech 17.5 boosted
Hello everyone.
It needs a setup Tekin Rs Pro.
Class 1/10 on-road 17.5 boosted.
Fantom Apex Motor or Trinity RevTech.
Link to the setting Hara are not needed. Its configuration is not suitable, this engine is overheating.
Experience with the previous one event in this combination in 2012 Snowbird Nationals.
It is very necessary.
Hello everyone.
reference to the setting Hara does not need those settings nepodhodyat, this motor with overheating.
Navernika someone riding in a given combination of the 2012 Snowbird Nationals.
Hello everyone.
30*16
My friends, there is anyone alive?
Hara's setups should work just fine if it's geared for the track you're racing on. How long is the straight away?
