Tekin RS ESC sensored
Team Tekin will be at Speedworld this weekend having fun and helping racers with RS set ups. If you're local or a short drive away come on out. Track opens at 8am and the RS revolution starts once my tire's dry
Hi guys, I have just taken my RS Pro from my SC truck, and rewired it for my 1/12th circuit car. The only problem is that now, on power up, the 1st, 3rd and 5th LED blink very fast, and there's no power to the motor! The servo/RX work fine, but no drive at all. I have re-installed the latest 208 software, but the speedo still does the same thing. I tried a differant motor, and differant sensor wire, but it still does the same!
HELP!!
But seriously, if anyone knows what is going on, and how to fix it, please let me know! Many thanks, Chris.
HELP!!
HELP!!
HELP!!
well i can say that my 12th setup with a redline 13.5 compared to others that have duo2 is that they need 15-20 more timing and gear just to keep up and the same with the x12.i run no turbo setups with redlines and the murfdogg 13.5 and others use turbo and motor timing
HELP!!
HELP!!
Hi,
There's only one software 208 1/12 scale setup on the Tekin website--and it's for 13.5. I started there. But---does anyone have a really good setup for 1s/ 1/12 scale on carpet-- Tekin Rs in an associated car--Novak 17.5 motor w/ stock endbell timing? I'm racing this weekend and a call to Tekin got me no help at all. Just -
"email" Randy Pike. But when I did that---I got an auto-response saying he wouldn't get back RE: sponsorship for 4 to 6 weeks!!!
NO one could answer any questions at Tekin---then--"try the chat room"!! NO ONE THERE EITHER!!! Geez---it's a simple question about their products?
Help!!!
Tim
Help!!!
Tim
Motor timing can vary upon driver feel and temps. He's saying somewhere between 0 and 8 degrees.
All sorted, thanks very much! And to the person saying that they could not get any help from Tekin, I made a call to them a little while ago, and chatted to 2 differant people about getting the max from their products for over half an hour! Could n't do much better than that I think!
Trader Rating: 25 (100%+)
Appreciate you got back to me same day!
Thank you
Tim
dbl post
Never seen or heard of a sales rep that you can contact 24/7
When do you sleep
When do you go play
Not to mention your other half must be pleased when you answer the phone during intamate moments
And I have also never seen service like tekins
And I work in the service industry
Randy takes alot of time not only on here put also answering ppls emails
I know this cause he has helped me lots of times and has even offered his services via yahoo messenger will track side
So I guess what I'm saying is take a chill pill and ppl will get back to you when they have the time or the information you need
Or as Randy said there is ppl on here that can help
When do you sleep
When do you go play
Tekin support
I had a software download issue with my Netbook computer, called Tekin and talked to Chris a number of times and helped fix my issue. Super service with Tekin
I run 12th 17.5. Running a Trinity Nemesis and Duo II. On the advanced timing setting in V208 what is a good setting? I have around 10 degrees on the motor now. Dose everyone set 0 timing on the V208, then set it on the motor? The track is big, rolling corners and medium traction.
Thanks in advance for the help
Greg G
Greg G
