Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-26-2008, 04:36 AM
  #7771
auzzy_mate's Avatar
Default Traction Roll
Originally Posted by rcmarek
Hi guys, I swapped my ages-old black can with the 3000kv hobbywing combo. The added speed (my black can was really tired) started to cause some traction roll. I'm using Team Powers 36s on the front and 32s on the rear. I used to use blue/yellow springs back/front based on the basic setup on rc-mini.net. It worked for me very well until now.
I tried to swap the springs for white/blue which slightly improved the situation.
Can you please suggest other changes that I should try to get rid off the traction roll?
Thanks Marek
Lowering your ride height to 3-4mm in the front, and 4-5mm in the rear will help.
Also the sway bars / roll bars will help distribute the weight better.
60wt oil in front, 40wt oil in rear will help also.
Ben
auzzy_mate is offline
Old 11-26-2008, 04:45 AM
  #7772
auzzy_mate's Avatar
Default Foams
Originally Posted by doki71
thanks for the reply...
how about on asphalt? any feedback?
im new at this, sorry if i ask to much..
I used these tyres before and on ashvault you can get a lot of slip in and out of turns. I have been shown the way and the Team Powers 36/32 with medium inserts are the way to go.
Ben
Old 11-26-2008, 06:22 AM
  #7773
doki71's Avatar
thanks ben.. one more thing.. where will i place the 36? in front?
doki71 is offline
Old 11-26-2008, 11:47 AM
  #7774
tony gray's Avatar
Thanks Marek
At the risk of infuriating the importer...the 32's are...well....problematical.
On some cars/setups they cause severe traction roll.
Initially, keep them on but maybe try the CA glue trick on the sidewall.
It's not your suspension settings because they worked for you before - until you changed tyres.
If it still traction rolls, switch to 36's all round (thats what I use) and/or lob a little bit of weight inside the bumpers..
tony gray is offline
Old 11-26-2008, 02:41 PM
  #7775
NT
NT's Avatar
Trader Rating: 21 (100%+)
I've tried the Spice 32's and couldn't get them to work at all with my current set up. I didn't have much fun with them at all! "Evil" is their new label around these parts!
NT is offline
Old 11-26-2008, 03:29 PM
  #7776
doki71's Avatar
where could i order team powers 36/32? cant find any in ebay and theres none here in our country... the only tire for minis that i found in ebay are the 3racing radials.. thanks!
doki71 is offline
Old 11-26-2008, 03:43 PM
  #7777
NT
NT's Avatar
www.harrisrc.com.au
NT is offline
Old 11-26-2008, 04:27 PM
  #7778
Ron C.'s Avatar
Default Lipo Batteries
Guys,
This may have been asked before but what Lipo Batteries would fit the Mini's Battery Compartment?
Thanks.
Ron C. is offline
Old 11-26-2008, 04:54 PM
  #7779
tony gray's Avatar
Orion 3200, Yeah/Core/Harris 3200, Harris 3700... Well they're the main ones.
Old 11-26-2008, 09:49 PM
  #7780
f1larry's Avatar
Trader Rating: 22 (100%+)
If anyone is interested I have a nice Mini M03m swift for sale here
http://www.rctech.net/forum/r-c-item...ml#post5098420
f1larry is offline
Old 11-27-2008, 12:37 AM
  #7781
R/C Tech Elite Member
heavy's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Ron C.
Guys,
Thanks.
CORE 3250 fits like a glove.
heavy is offline
Old 11-27-2008, 03:07 AM
  #7782
auzzy_mate's Avatar
Yes, I ran new 36's on the front and "matured" 32's on the rear and it was just brilliant to drive.
Ben
Old 11-27-2008, 05:30 AM
  #7783
What should be the normal wear pattern on the front tyres? Mine are X-patterns and show more wear on the inner part. This looks OK or do I need to make some ride height changes? My track goes counter-clockwise now, which explains the heavier wear on the right.
stocker is offline
Old 11-27-2008, 09:08 PM
  #7784
doki71's Avatar
wheeewww... team powers are expensive..
how long does the tires last? how many races? rough estimate.. thanks!
doki71 is offline
Old 11-27-2008, 09:11 PM
  #7785
monkeyracing's Avatar
That wear pattern is fairly typical. I don't know how many tires I've had to trash that still had loads of tread on the outside edge, and were worn completely through on the inside. It's just the nature of the beast.
Jim
monkeyracing is offline
