Tamiya Ta06
#406
can someone tell me which battery would fit in the ta-06?
#407
#409
For the front pulley holder, I used different methods for the two screws to hold that piece down. For the front side, I used a little longer screw and put a lock nut from underneath and for the rear side, I used a fairly long screw (20mm). This allowed me to torque the screws really tight to prevent the pulley holder from moving. This should do until someone makes an aluminum version.
check part #3454516
Tamiya TRF416 belt stabalizer mount. Aluminum... Im checking to see if its cross-compatible.
#410
How much fluid is everyone putting inside the diffs? I've read about half the internal volume, I've read plum full, I've read to just wet the gears,...ect. I am finally getting around to building and was curious where I should start. I am planning on doing half the internal volume and seeing where it goes. I hate splashing around in that stuff any more then I have to.
#411
As for having too much flex, I was referring to the flex towards pitching, which loosens the belt under braking. This comes from mainly 2 areas. The first area is the front where the chassis stiffeners attaches to the wall of the battery compartment (circled in red). The wall is soft so is caves in pretty easily. The second is the area where the 4 screws meet the motor brace on top the battery box (green area). This also caves in. Try it with your hands and you'll see just how much the belt comes loose. The trick is to fill the battery compartment so that the walls cannot cave in so easily. You are essentially using the battery case as an internal brace. Foam alone is not strong enough fyi.
You won't lose any twist flex because the chassis is so soft to begin with. But pitch flex is not good for the belt and weight transfer.
btw, I switched to outboard shocks, and the weight difference was negligible. Also, a 30x30mm fan fits perfectly on top of that motor brace. If you use all four screw holes, it even acts as a stiffener.
#412
#413
Im waiting on mine to come to me in the mail(got it from rcmart on ebay for $400 with both front and rear diffs-SHIPPED!)
inpuressa; the Pro kit comes with the normal plastic battery box right? what about the graphite battery box?
#414
has no one bought the ball diffs yet?!
I don't like the current tamiya ball diffs because the diff rings don't have the D-cuts. You need to maintain it often to make sure it doesn't start slipping. Another advantage to the gear diff is how the outdrive bearing is mounted. On the ball diff, the bearing is mounted on the outdrives. If one of the bearing seizes, your diff action will suffer on that side, giving you weird handling (personal experience). On the gear diff, your differential system is independent from the bearings, so you don't have that.
#415
Tamiya is known for releasing the carbon reinforced chassis pretty late. I think they are releasing the FF03 this month, and that car was out for sometime already. The other parts tree, we should see in a couple months. Parts tree A will be the most crucial.
#416
This evening my TA06 PRO was delivered and i inmediately started the building proces.
So far the car is coming along nicely, but i was also surprised about the chassis flex (very much flex).
Maybe that's an advantage on low grip circuits.
I will finish the car tomorrow, hopefully i will get the electronics in so i can test it on sunday
#417
Trader Rating: 89 (100%+)
diffs
Has anybody tried to run the rear gear diff with the spool up front? How will the car react?
#418
my TA06
is it the 1st one to modify ESC and servo position?
I think ESC sit near the motor make shorter wires...
#419
I really like this mod, he just switched everything from L to R
but i think it does not compensate all the weight... you still need some ballancing weight.
#420
Today i was able to test te car and i was surprised by the handling.
The car had lots of grip on a low grip track.
I really like how the car is build up, it shouldn't be that difficult to get the perfect balans (front to rear and left to right side).
I will be testing some more to get the best results out of this car.
