Hpi Pro 4
#4606
Well, the first run with the pro4 was pretty success ful this tuesday. I ran it outside with close to a kit set up. I had it geared wrong with the 9 double. It got hot. to lazy to rebuild it. So I put the 12 double in it. It threw a wind on the 2nd lap. So in went the Chameleon. I put the biggest gear I had on it. LOL I was passing 10 turns on the straight with it. I tqed and won the main by almost a lap. And still had 40+sec of runtime left. Was fun. I had a 39 pinnion. stock spur. Never got hot either.
I like the car. Still working on a small left turn issue. But the sway bars were not centered and not equal. Fixed that, See what happens this weekend. Can't believe how quiet it is for a shaft drive car. Darn belt cars are noisy. LOL
Kit set up Minus the 3 mil blocks in rear and 3 mil block in rear front and 2 mil front front = 1.5 degree with of anti-dive in front. Asc Red springs Front. Blue Rear. Everything else is kit.
Big asphalt track. 160+ Foot straight.
I was running sorex 28's. The sun went down and we ran under the light. put pit 24's on it for the colder track.
#4607
Ray - I race with Billy S. (AKA D)
Just some FYI>
Just some FYI>
#4609
Can I have my 39 tooth pinion back now? When are you going to run again 2fast?
#4610
RAY - LOL> I run nitro normally outside in summer. Being that I focus on Nitro alot more then Electric. Winter is a time to race electric to keep the reflexes up and not loose to much of a edge for Nitro. I saw the pro4 and was like, that looks cool. It has been making me kinda itching to run it. So I did Tuesday night.
Its pretty cool to run outside under some lights. Not perfect conditions, but it was a blast.
Later
Tim (AKA BEAR)
Later
Tim (AKA BEAR)
#4611
Uh, I will be running it Sunday, Weather permitting,
I may need to borrow it untill Eroc get some more gears in.
Unless you need it. I will leave it at hobbytown for you.
I will be by there after work to pick up my new body.
Did you see it on Fastlanes Thread. Ian posted a pic.
#4612
Nope I wont need it.Keep it till we run again.
#4613
Tech Legend
Trader Rating: 51 (100%+)
Just some FYI>
Just some FYI>
#4614
Yea, he had to keep up with the south chapter of the racing team!
#4615
Zombie,
any idea how can make this web site (http://www.rc-square.com) to come out in english version?
thanks.
thanks.
Originally posted by rc-zombies
got my Ti input shafts from Rainbowten...and Square makes a ton of option parts for the cars..and I don't they are done yet...
http://www.rc-square.com/
alot of the parts on my car are from Square... except for the transponder mount and servo saver set which are from Jet.
#4616
Paging TSR6 & G Katzer
Hey TSR6 and G Katzer I need a little help, actualy any one can help. What setup are you running at Trackside? With the control tires - CS27's all round? I finaly found the time to get my pro 4 built. It took way to long but its now almost done. Thanks for all the help..
~Snowy.
~Snowy.
#4618
Snowy, Will you be at trackside tuesday? I always show up really early (~3:00), and I can help you out.
I'd really hate to post anything without having a car, or setup sheet in front of me.
I can give you the basics, but for camber link and hingepin block shims, I would just be guessing without having the car here.
#4619
Has anybody seen the driveshafts that are on the HPI Japan site? They are more like a dogbone than a CVD. Plus they have steel ones as well? Does anybody know if a TC3 cvd bone will fit the car? I have one slightly bent and saw some MIP shiny cvd bones for the TC3 that might work till I can get a replacement PURPLE cvd bone.
How well will a graphite center drive shaft hold up to open mod? I thought I read somewhere that on the TC3 they went back to the alum shaft for mod racing for strength.
#4620
Yes.. the TC3 bones is a direct fit. any 50mm MIP bones will work.
A bend dog bone can be easily straighten out with a hammer..
