Old 01-12-2009, 12:35 PM   #6751
Moderator
Clegg's Avatar
Oh and here is the updated setup that I ran yesterday. I did need more negative camber for some of the higher speed sweepers we have, but that was about the only real change I made.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 01-12-2009, 12:36 PM   #6752
lyoha's Avatar
Please optimal gear ratio for the modified motor for 3.7. And what the motor used in modified?
Tamiya TRF-416WE - Speed Passion GT V2.0 - EPIC 10.5
BMI12RR - Sphere SSX - Vector X12 4.0
CRC Gen-X - Speed passion GT - Orion Vortex 5.5
Futaba T3VCS 2.4 FASST
lyoha is offline   Reply With Quote
Old 01-12-2009, 12:37 PM   #6753
Moderator
Clegg's Avatar
Originally Posted by protc3 View Post
I am about to do some lipo testing with the 3.7 lipo. I am going to try this setup
Front
5 degree blocks with 4 degree castor
.020 front spring w/ #3 on the kingpins
angled servo
2x pink fronts cut to 1.700 1/2 inside sauce
2 degrees camber
0 toe
3.5mm ride height
.25mm droop
Rear
lipo back as far as possible
Thin flex plates in long position w/ set screw installed but not touching chassis
#3 in the tubes
Gold spring w/ 50 wt. oil in the silva shock
Tall ballstud on shock mount
2 x pink rear tire cut to 1.800
1mm pod droop
3.5mm ride height
pod level
I will see how this runs and let you know.
Any reason you are going with the angled servo and not flat for the LiPo testing?
Cant wait to hear how it works!
Old 01-12-2009, 01:40 PM   #6754
protc3's Avatar
I always start with the angled mounts for the most aggressive feel. I will tone it down if i need to.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-12-2009, 02:02 PM   #6755
anyone had problems with the motor moving forwards in a shunt ?
I've had this a couple of times now and I can't work out what it is.
CPD Racing
chris_dono is offline   Reply With Quote
Old 01-12-2009, 02:09 PM   #6756
Moderator
Clegg's Avatar
I think I did in one of the qualifiers yesterday. mid way through the race I started hearing a bit of grind and pulled it in.. the motor still had mesh but not much and started taking the tops off the spur teeth. So I jammed it back together and all was good
I normally run my mesh a bit lose and that could have caused the teeth on the spur to wear and start to break a bit.
Old 01-12-2009, 02:13 PM   #6757
the spur was new that day and it's not damaged from what i can see
the motor has moved enough along the pod plate that the pinion is no longer in contact with the spur
CPD Racing
Old 01-12-2009, 02:25 PM   #6758
chris moore's Avatar
Trader Rating: 87 (99%+)
Front
angled servo
2 degrees camber
0 toe
3.5mm ride height
.25mm droop
Rear
#3 in the tubes
1mm pod droop
3.5mm ride height
pod level
Are you doing this test on asphalt or carpet Jason?
If your motor has moved that much you must have hit a board/object square and hard or the motor screws are way loose. Another cause could be if your using a washer for the motor screws thats not metal. I used to use a plastic shim and it would slide if I hit something hard.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 01-12-2009, 02:27 PM   #6759
protc3's Avatar
This is caused from vibration from the motor. You can run a slight amount of blue locktight on the threads for the motor screws.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-12-2009, 02:28 PM   #6760
in the year I've been running my DB12R I've only had that happen to me once. I just didn't have the screws tight enough.
Old 01-12-2009, 02:29 PM   #6761
That's what I thought, but they aren't loose at all. When i set the mesh up on the pinion I put one tooth higher and have it as close to the spur as it will go, then crank the motor screws tight.
I then change down 1 tooth on the pinion for a good mesh without moving the motor.
It's moved along the podplate without loosening the screws :S
CPD Racing
Old 01-12-2009, 02:33 PM   #6762
protc3's Avatar
Hmm, That doesnt sound right. If you like, You can send the car to me and i will get it squared away. I can send it back the same day it gets here. It shouldnt take long.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-12-2009, 02:43 PM   #6763
I'm 95% sure it's me not the car Jason, but thanks for the offer. I'm racing a national this weekend otherwise I'd send it
I'm going to try a new set of pod plates this weekend and a different motor. I'm currently using cap head M3x6mm screws (2mm hex) to hold it in place, perhaps I should try a slightly longer screw and a washer to grip the podplate ?
Didn't see about loctite, will try that first
CPD Racing
Old 01-12-2009, 03:07 PM   #6764
fatbear's Avatar
Send a message via Yahoo to fatbear
Jason, (or anyone for that matter) can you please explain what changing the front droop does for the cars handling.
ie; changing from 3 shims to 2 shims above the upper pivot ball.
Is there an optimum difference in tire dia from front to rear? Perhaps a ratio you can use like the rear tires are for example should be 1.05 times bigger than the fronts.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 01-12-2009, 03:22 PM   #6765
Default My New ride,ready to hit the track Sunday
Just completed the build 2 hours 40 mins and another 2 hours kit it out.What do you think guys.
BMI 12RR If it goes as well as it looks watch out.
tellan is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
