Speedpassion Brushless.
#830
R/C Tech Elite Member
Shawn and I agreed that 3.0 is the absolute lowest that you should have it set at.
(which neither of us recommend by the way)
I said #5 which i believe is 3.2?? only because its ALWAYS better safe than sorry.
My goal is not to extend per say, but make sure you can utilize the entire life-span of your battery, and that one of our products isn't the reason its been cut short.
If your solely using this battery/speed control combo for racing, it won't really be an issue because even in practice you normally will only run 8 min max at a time, and the cutoff voltage wont even come into play...normally
#832
Man Alive, this is a blistering set up. Night and day to the Novak. The programability is astounding. Ran 5 lipo packs last night (1 pack 5 times that is). Set # 3 at 5 as per Adam's message-fine. Just to see what happens, I set #3 at 6, highest cut off voltage, thinking there might be a voltage drop glitch; no a one in a five min heat plus 1 minute warm up !! Played on the punch setting, starting at 8=great, one heat at 6 got me quicker, one heat at 9, got me faster !! Know what's coming from this ?? But who can resist that punch......
Didn't have time to play with the reverse brake (?) function, in fact, it's a bit of a contradiction in my febble mind sitting here at a terminal. Better read the book when I get home.
Jacko
Jacko
