Serpent to 1/10th EP Touring Kit S400
#1728
Super Moderator
#1729
Randy-Sorry for the late response..I was out of town. The stock belts are too short. You need to use longer front and rear to get the 18 tooth pulleys on.
Works GREAT!!!
Works GREAT!!!
#1731
bro randy, is it u mean bout this ? using tamiya swingshaft must use this cross joint to prevent fast wear out ??? do i need to use d tamiya axle as well to fit it ??? my 48mm swing shaft arrive y'day..it's fit perfectly for d rear...but d serpent cross join abit loose when put into d swing shaft,.....
#1733
R/C Tech Elite Member
#1736
Anti-roll bar locations on wishbones: what effect will using sway bar on the inner position(closest to chasis) vs using the outer hole position(closest to tires)?
Also, will using the narrower front clamping wheel hex hubs, like SER401129, which are -.5mm hubs, thus narrowing the front track width, this should in theory increase front reactiveness, over-all steering, and corner entry?
I'd like to use a narrower front track width: FF susp bracket 2.0, and FR to 0 deg...which tamiya TRF suspension brackets will give me that combo?
#1737
Yohan- We already covered most of those subjects on the phone but the suspension brackets you can get from Serpent direct. They have optional ones in .5 increments.
See you wednesday night. Let's see who else we can convert!!
#1739
hi guys, any1 using foam tyre in asphalt surface ?? can i use 26mm infront and 30mm for rear ??? i'm planning to use it for practising so tat i can save some rubber tyre for race.....will foam tyre more grip than rubber tyre ??? wat is d reconmended tyre treament for foam tyrE?
thanks
thanks
#1740
Randy pm
