Yokomo MR-4TC SD
Originally posted by JayBee
does anyone know what degree of caster the front hub carrier has on the stock SD? just looking through my parts and realized i have some 4 degree graphite ones. also, just got the RS new geo. frt. shock tower and on the package it says (FOR SSS-SIZE), does this mean i can't use the longer SS shocks? and the tower comes with hex nuts & rubber grommets, what are the grommets for?
something i thought was a bit weird is why does Yokomo package the frt. steering block w/ the rear hub carrier instead of with the frt. hub carrier (#SD-4134G)?
- jaybee
- jaybee
Since the discussion seems to be centered on the suspension right now, maybe some of you could share your secret for threading the king pins in straight to prevent binding in the steering. I've tried using the king pins that use the colar, but with only limited success.
Believe it or not, installing the king pins is always a major source of frustration for me.
I don't know what to tell you, I haven't had any problems with the kingpins binding the steering with either the stock kingpins or the coller/screw ones.
Is it possible to have the car PERFECTLY flat, parallel to the ground with perfectly EQUAL left-right tweak or downtravel?
if they are not straight, have you forgotten the shims?
Anyone got any news on a reliese date for the MR4 SDW yet? Rick
Originally posted by Matt Howard
I already emailed yokomo usa today and hopefully will get an anwer today as well.
Screw in about 3 to 5 treads on the top and then the same on the bottom. Then screw the top pin all the way, the sleeve on the top won't really let you screw in the pin any way but straight. Then finish the bottom screw, you should have no binding.
Yokomo USA should have the SDW's in sometime next week so they're probably out in japan right now or they will be soon.
maybe when the car is absolutely box stock new but after you run it things tend to "shift". It's just that plastic pieces will not stay exactly the same with wear so you might have one shock slightly longer than the other after running for awhile. Also, if you're involved in a big wreck you might want to loosen all the top deck screws, put the chassis on something perfectly flat and then tighten the screws back down to prevent chassis tweek.
it is possible, see if someone you know has a hudy set up station, it gets everything perfect and also provides a nice smooth flat surface to fix chassis tweak on
I'll try some of the suggestions offered here.
put it as straight as possible. push down hard and screw in slowly. dont blame me if it stuffs up
