Yokomo MR-4TC SD
Originally posted by Lonestar
Well, he could be trying stuff, I guess... I think he usually runs GM speedos (at least since the last worlds, when he actually switched brands during the race if I remember well).
btw, hail to the KING, the guy who will lap you at your hometrack, driving with his feet
Paul
Paul
Haaaaiil to the Kiiiiing (just making the chorus)
Paul,
Naaahhh, I reckon you could take him!
Just remove his thumbs AND toes before the race......sorted!
Originally posted by Horatio
Paul,
Paul,
MRTC-SDW
The picture on Orion's live site is of Billy Eastons SDW.
Here's a bit of info on the kit (posted some of it as a translation from a Japanese page last week).
MRTC-SDW SD World Championship Replica
- limited to 555 kits
New parts:
- aluminium bulkheads and new "floating" motormount that lower the drivetrain 4.5 mm and the upper deck 2.0 mm.
- front short span suspension arms with new aluminium suspension mounts
- new chassis, upper deck, shock towers, battery plate, rear body mount, bumper support and roll bar plate from normal "black" carbon fibre 2.5 mm
- full aluminium universal driveshafts, both bone and axle (i.e. YMP version)
- aluminium ball studs
- carbon fibre hollow main shaft
Kit will include the following option parts:
- titanium screw set
- super precision bearing (drivetrain)
- titanium turnbuckles
- aluminium input shafts
- aluminium rear suspension mounts
- front roll bar (Rayspeed)
- rear roll bar (upper type) (same bars as front upper type but mounted in normal position at rear)
- HD rear suspension arms
- bump stop o-rings
Rest is to the same spec as the current SD SSG and Black versions.
Should be available early December (555 kits).
Remember this is an exclusive World Championship Replica kit exactly to the same specs as Masami's car at the worlds. Pretty sure we can expect a 'normal' version early next year with more 'user friendly' driveshafts, steel input shafts, steel ball studs etc. to a lower price of course.
New parts:
- bump stop o-rings
MRTC-SDW Picture
Just found a good picture on CML's site. The same info I just posted on the specs of the kit is is posted on their site as well. http://www.cmldistribution.co.uk
Here you go!
Here you go!
Re: MRTC-SDW Picture
Here you go!
Here you go!
I was told if the worlds go well then there will "probably" be a cheaper version coming out with molded gearboxes and less items added. As it is now the car will be very expensive, that's why it's a limited edition.
I can see that the Evo 4 doesn't suit you then
I have already got a 1/12 scale CEFX sat here just waiting for a servo and tires then i will be running that at chesterfield. Rick
can you say barracuda?
Aaahh, but Barrcudas are silly because they have the cells and motors the wrong way around.
I once got seriously flamed for mentioning this on their thread but no-one really came up with a satisfactory argument to counter what I was pointing out.
I s'pose the cuda would be good on certain oval tracks though....
Not that I'm stirring or anything - but personally I think AE and Yokomo got it right. It's not a coincidence.
Since converting my SSG to CGM my TC3 has become my spare car... Probably going to give it to my 5 year old son....
Seems to be an interesting update .... I am surprised they have opted for the twin deck configuration once again ..... I am constantly hearing that this type of config tweaks very easily..well it seems Masami and Yokomo know what they r doing ...good luck Masami
Why did they leave the bulkheads silver? Make it blue!
