Yokomo MR-4TC SD
any new setup for a tight asphalt track? lets say 30 x 20? im goin to use an SD LCG woohoo!!!
PM or attach the file. TY
I really wish this car still had the following it deserves.
The original version SD is super stiff and an excellent carpet racer.
Now if I could get some good starting setups to get me going in the right direction, Id be happy.
the sd is a great car. i love mine. setups for a tight asphault track.... is it rough or real smooth. and what will be the tipical speed into the turns?
Regional Moderator
Have a look here http://www.cmldistribution.co.uk
look under Downloads - setup sheet and select Yokomo MR4TC SD. You should see a whole list of setups that are good starting points.
HTH
Thanks for the responses.
The track I am running on is carpet how ever the surface has a little bumpiness to it. At least now I have a better direction to move in.
I love this car
Its just as fast as some of the corallys/xrays at my track.
I switch back and forth between my Jrxs and Mr4tc sd
I think the yokomo is a little faster.
its all i nthe gearing and setup. i can easily keep up with all the xrays and all that at my track. motor and gearing makes the biggest difference. but the car itself is great.
hey guys anyone who runs a LCG if you are looking for a 3mm carpet chassie i have a guy who makes them. i put one on my car for a race a couple of week ago and it made a big diff!!! that car was alot smoother in and out of the corners. and is real stiff! if you have any questions or would like to buy one send me a pm and i will get back to you! he only has a couple left!
Slop in ball joints
There seems to be an excessive amount of slop in the standard Yokomo SD ball joints and I'm looking to replace them with alternatives. Has anyone done this on their SD's? If so, what joints did you use?
Originally Posted by Racingbod85
The anti rollbar open loops are a great alternative. mine are very old and still no slop. may even need to give them a squeeze to loosen their grip when new. or try the bx ones. not sure if their better but you can get the ball studs off without removing the ball joint. some people use the fasttrax ones too.
LCG Indoor / Outdoor Asphalt Set Up
Hi,
I have an LCG and run at combination of indoor and outdoor asphalt tracks.
Can anyone recommend a set up ?
I currently use:
- Rubber tyres Sorex 32/36
- rayspeed springs - grey front & yellow rear
- 2 hole rayspeed shock pistons / 40 wt oil
- no sway bars
- 5mm ride height F & R
- 2 deg rear toe block.
I currently use:
- no sway bars
