Yokomo MR-4TC SD
i use my stock suspension on my black special, so i dont know what stiffness springs they are. i am running sway bars front and back and ive noticed a difference from when i dont run them. i have the same 2 degree toe and 5mm ride height, but depending on how smooth your track is, you could lower it a mm or so. i use hpi 31mm super wide radial tires and love them, but we dont have any rules on tires, so those might not work at your track.
i alternately run my LCG with my BD. both have the same set-up. track in indoor asphalt with low to medium grip
2deg camber front and rear
no spacers under the suspension pin mounts
1mm spacer on the bulkhead camber ball mounts, front and/or rear
shocks mounted on the 2nd from the outermost hole, front and rear (but i sometimes put it on the 3rd hole on the BD)
5mm ride height
6mm on the droop gauge (hudy) for the front
full droop at the rear (remove the droop pin)
stock sway bars front and rear
2deg rear toe block
0deg front toe
sorex 36R with medium type b inserts, hard wheels
Paragon FXII sauce
i run 27T stock
5mm ride height
2deg rear toe block
0deg front toe
Paragon FXII sauce
i run 27T stock
LCG Indoor / Outdoor Asphalt Set Up
Thanks for the tips guys. I'll trey some of those out
Hey VooDooPH, I also run 27T stock.
Could you tell me what spring, piston & shock you use ?
i dont race stock so i cant tell you anything on that. i race open brushless. im running 30wt oil i nthe shocks, so i would think 30-40 would be fine. its a yokomo lcg, so chances are that it has stuff that is set for racing on it, so i wouldnt worry all that much about the shock pistons and stuff. worry more about grip, speed, handleing, etc. i dont mess with shock stuff other then oil weight and im fine with it. just my opinion though
LCG 2 ?
Thanks for all the tips guys, all the advice helps
Hey, was surfing the net for LCG info and came across an "LCG 2" on the Yokomo Japan website
As it was all in Japanese, couldn't undestand what upgrades are included, although I did see the previously optional 'long steering posts' in a picture.
Has anyone heard of it before and know whats new on it. Also, an link's to websites would be great !
are you sure it was a LCG2? it could have been an upgraded LCG. just showing what you could do with it. i know rayspeed does that about the ssg version. they show pictures pf what can be done to it.
LCG 2
Hi Streetracer745. I initially thought it may have been 'fresh advertising' too...however then noticed it was labed "LCG 2".
I have since found another link in English, it seems it's nothing to get excited about after all . It now has a "stick-pack compatible chassis", rest is the same.
Here's the link, its listed amongst the new products.
http://www.teamyokomo.com/japan/newp...2006_10_en.htm
Hey, I heard Team Bomer make a thicker LCG chassis, anyone seen it / got one ?
has anyone put the yokomo muffler set onto their SD? i want to put it on.
Just out of curiosity, will the SD top deck fit on the CGM? How stiff is the stock CGM, as far as enough for foam or is there quite a bit of flex?
I would use the Rayspeed top deck, and yes the CGM is stiff enough for foam use. In the stock class it's a very good car, Cheap and fast. You can still find deals on them. A Rayspeed SD car is also good.
recently picked up some BD-500a aluminum diffs for LCG fron and rear diffs. I will be testing them out soon, heard that they notch pretty easily.
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
do notch pretty quickley ,they file out slots to insert blades ,serious filing here as the ali is quite thick
also brough a team bomber spool ,the blades just disentergrate in 1-2 races
only found 1 place that sells replacemnet baldes aswell
