Team Associated TC5
#7531
hey guys, after assembling the tc5r with the upperdeck countersunk/o-ring screws-did you guys notice a slight bind between the spur gear and the two orange o-rings that sits underneath the two countersunk screws?
i saw the o-rings sort of chewed away but the spur is not touching the countersunk.
i confirmed everything is shimmed correctly as far as the spur gear center pulley assembley goes.
did anybody else experience this?
thanks
thanks
#7536
#7537
should i loosen them so they dont stick out? duh
#7538
Yes they should be under the countersunk washer. Might try without the rings too if you use the ITF chassis and top deck...more resistant to tweak and I tried the rings but found I already had enough torsional flex without them.
#7541
3.75 or so is usually about right. I also run a 100tooth spur and have been using a 53T pinion for a 3.77.
#7542
Thanks for the input with the gearing question I had, but I must be missing something.
Do you divide the Spur gear number by the pinion size? 100T spur using a 50T pinion would be a 2 fdr? or am I forgetting something.
What company makes 50T pinions? What dose everyone use?
Thanks guys!!!
Thanks guys!!!
#7543
Thanks guys!!!
Thanks guys!!!
Spur/pinion*IR=FDR
(IR=Internal Ratio)
(IR on a TC5 is 2.0)
100/50*2.0=4.0FDR
#7544
Thanks guys!!!
Thanks guys!!!
http://www.precisionracingsystems.com/catalog/4
