Team Associated TC5
#5116
Hey guys gonna jump into the TC5 arena this weekend so I have a couple questions. I'll be running 13.5 rubber on carpet.. so as I look at setups all rubber setups I've seen so far have the ITF chassis. Well I won't have the ITF for awhile so what adjustments do you think need to be made to use the stock chassis?
Thanks,
Paul
Thanks,
Paul
#5117
Super Moderator
Paul, I don't think you will have to make to many changes. If the setup calls for the 4 o-rings in the back I would definately do that. Otherwise, the chassis will work on rubber tires without any problems. I have done it for awhile now until I got the other chassis.
#5118
Droop is something that you set with no weight on the shocks. Setting them at 6 and 7 to the bottom of the hinge pin is fine but I can't get ride height with it.
I'm not trying this for foam tire racing. With foam tire racing droop is not really used. It would be more down travel. Set your ride height at the start and then limit how far you can lift the car before the wheels will lift from the ground. Kinda the same but different with droop. It doesn't change from the beginning to the end of the run.
#5119
Both things you described are droop. You can set it using a droop gauge or you can set it "above ride hieght". But both are droop settings.
#5120
So if you use the droop guage with the tires off and shocks removed and want to set your rear droop to 7 (like with the Cleveland setup) you measure it at the end of the arms to 7, then put everything on and set ride hight, correct? This seems really simple but I have searched around and everyone seems to have a different explanation or way of doing it.
#5122
Thanks,
Paul
Thanks,
Paul
#5126
hi, I've had a problem with wheels on the TC5 coming off about 4mins into a race. I've changed the stub axles - but there's still a wobble in wheel. I'm using nylock nuts. I'm starting to wonder if it's the CVDs. Has anyone else had an issue with this? Thanks for your help in advance.
Shev
Shev
#5128
Super Moderator
Shev
Shev
#5130
im using 115t spur and 44pinion....and motor gets really really really hot...oh im using 4.5LRP brushless with lrp sphere....i dont have the capacitor on the speed control though....is my gearing wrong? or is it cuz i dont have the capacitor? (the cap burnt!)
