TLR 22 3.0 Race Kit Thread!
#4292
You need a -2 degree rear toe plate (TLR334034) then use the 3.5 toe pill to make 1.5 degree toe.
#4293
Can the lightweight chassis (231056) be drilled to accommodate the laydown transmission?
#4294
What is the recommended FDR for a tight track on carpet (12 second laps). I will be running a 13.5t motor. What spur/pinion do I need to hit the FDR?
Thanks,
Thanks,
#4296
I'm running a 78/29 on a fairly tight really high bite clay track. Motor temps are perfect after even a 6-8 min run.
#4297
Frank
I was looking on Facebook and saw pictures from the rumble and Kevin's 3.0 seemed to have a molded stiffener to brace the rear shock tower for shocks in the front of the A arms mod.
Is it a mod cutting the top of a tower off?
Or Something in the "Works"????
#4298
Thanks.
#4301
Does anyone happen to know what camber block this is?
http://site.petitrc.com/setup/losi/s...17021112/8.jpg
#4302
R/C Tech Elite Member
#4303
