    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree10Likes
Old 11-24-2016, 10:06 AM   #2581
shadaloo's Avatar
Originally Posted by qstorm777 View Post
What batteries are you running? With the SMC batteries, the S1 doesn't fit. They said it was because of the battery size.
i haven't had any issues with it fitting, i have the 6500/60 and the new 6700/90. As long as I have the wires pushed to the middle of the car its fine.
[current]--tekno sct/eb/nb --tekin/mks/aka/futaba/smc
[rip]--losi scte/xxx-nt/xx
[wishlist]--tekno nt --reds/blok
shadaloo is offline   Reply With Quote
Old 11-25-2016, 06:29 AM   #2582
Dr_T's Avatar
Hi guys, quick question: what's the smallest pinion one could use with the 44T spur and a 42 mm diameter motor before motor hits the chassis brace?
Thanks!
EDIT: Nevermind, search first, ask later would have been better :
Originally Posted by Matthew_Armeni View Post
The smallest pinion you can run with the split diff and the 44 tooth spur is 14 tooth. If you run the old diff mount (and omit the center brace - or shave it down a lot) you should be able to fit a 12, definitely a 13. I haven't run a motor that needs to geared that low in a long time and I can't remember for sure if the 12 fits. A 13 will (with the old mount) and gives you the same top speed as a 1900kv motor geared 18/44. A 14 tooth is a little faster than a 1900 geared 19/44.
2S is for servos, 4S is for minis.
Dr_T is offline   Reply With Quote
Old 11-26-2016, 12:12 AM   #2583
I see. It does fit that way. I'm a little worried about the wires hitting the drivetrain especially landing a jump. Any issues with that or how are you preventing that?
qstorm777 is offline   Reply With Quote
Old 11-30-2016, 06:56 AM   #2584
Can anyone recommend a setup station that would work for a 10th scale short course truck , 8th scale buggy and 10th scale touring car? or do these have to all be bought separately.
caffeine357 is offline   Reply With Quote
Old 11-30-2016, 07:30 AM   #2585
mkl
I think the touring car poses a problem for one station to do it all.
My Hudy 1/8 station will work with my SCT410, EB48 and ET48 (with truggy plate).
Touring car is so much lower I would think you need touring car specific adjuster plates.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 12-01-2016, 11:20 AM   #2586
Paultje040's Avatar
Does anybody have experience withe the Hobbywing XR8 SCT in the EB48.3?
Size wise it should be perfect as it is 30% smaller than the XR8 PLUS.
However the Hobbywing site states the SCT is 150A, all dealer sites state that it is 140A.
Schumacher KC
Tekno EB48.3
Paultje040 is offline   Reply With Quote
Old 12-01-2016, 11:31 AM   #2587
I've ran the older sct pro in my ebuggy for almost 2 seasons now, only thing I've had to do is replace the esc fan a few times.
https://www.amainhobbies.com/hobbywi...020262/p279090
anr211 is offline   Reply With Quote
Old 12-01-2016, 01:29 PM   #2588
I run the XR8 SCT in my ET48.3 and will be replacing the XR8 Plus in my EB48.3 with the XR8 SCT tonight.
Nothing wrong with the Plus - it's a smooth, powerful and adjustable speedo. But like you pointed out, the SCT is smaller and easier to fit in the Tekno vehicles. I really had a tight fit with the Plus in the truggy with a 72mm motor. And I have to say that the SCT feels more responsive.
Tampagoalie is offline   Reply With Quote
Old 12-02-2016, 01:52 AM   #2589
Paultje040's Avatar
Thank you for the reply. SCT it is.
Old 12-05-2016, 10:19 AM   #2590
Lambo1's Avatar
Just ordered my EB48.3 from Amain. It's on sale and I called and they matched a Tower coupon! Way to go Amain!!
Lambo1 is offline   Reply With Quote
Old 12-05-2016, 12:05 PM   #2591
shadaloo's Avatar
Nice! curious what did you pay? I know about 2-3 weeks ago there were crazy sales on almost all of the Tekno kits.
Old 12-05-2016, 12:50 PM   #2592
Lambo1's Avatar
On sale at Amain for $429, then they gave me the tower coupon ($48 off $399), so $328 shipped.
I was looking really hard at the RC8B3e at tower ($450). Happy with the EB. I'm getting started, so if they are blowing out last years model, I am ok with it.
Old 12-05-2016, 02:36 PM   #2593
shadaloo's Avatar
Nice, the sale I saw last month was Eb48.3 $348,. Eb48SL $270, NB48.3 $375, so you did good!
Old 12-06-2016, 08:33 AM   #2594
Lambo1's Avatar
tower just dropped the price to $429 to match Amain.
Old 12-06-2016, 09:28 AM   #2595
DEADWright's Avatar
Just ordered from Tower with $48 off coupon.
Also listed on Tekno site for $429
Tekno SCT410,EB48.3,ET48.3
DEADWright is offline   Reply With Quote
