Tekno RC EB48.3 Thread >
Like Tree22Likes
    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 – Yellow Low Frequency Rear Springs and TKR8762 – Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 – Orange Low Frequency Rear Springs and TKR8763 – Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B – HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 – Hinge Pins (inner, front/rear)
TKR6061T – Rear Shock Shafts w/ TiNi Coating and TKR6017T – Front Shock Shafts w/ TiNi Coating
TKR5286 – Front Suspension Arms and TKR5184 – Rear Suspension Arms
TKR5194 – Spindle Carriers
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 11-22-2016, 02:06 AM
  #2566
The information there is us full..going to start looking at the parts.. will update and post pictures of my build when completed.... thanks a lot.
SCATO is offline
Old 11-22-2016, 06:04 AM
  #2567
hairymuffin's Avatar
Trader Rating: 105 (100%+)
If any of you guys have a clear pl phantom body let me know
hairymuffin is offline
Old 11-22-2016, 08:19 AM
  #2568
Originally Posted by kpjr7321
Who knows where I can buy part #TKR5199B
NM...Wrong part showed up
ezlight is offline
Old 11-22-2016, 08:53 PM
  #2569
shadaloo's Avatar
there are still a few for sale online
shadaloo is offline
Old 11-23-2016, 05:53 AM
  #2570
2 in stock here.
http://fiercercsolutions.com/Phantom...PRO3432-00.htm
ezlight is offline
Old 11-23-2016, 06:25 AM
  #2571
Thanks guys!
Old 11-23-2016, 07:15 AM
  #2572
The .2 body, fits the .3 chassis?
JKresty is offline
Old 11-23-2016, 07:34 AM
  #2573
Sure does
ezlight is offline
Old 11-23-2016, 08:39 AM
  #2574
Trader Rating: 21 (100%+)
Yes, fits exactly the same.
MX304 is offline
Old 11-23-2016, 04:15 PM
  #2575
How about the SL body?
JKresty is offline
Old 11-23-2016, 04:51 PM
  #2576
shadaloo's Avatar
It's the exact same body, there is no SL body, unless you mean one of the lightweight bodies (thinner lexan?) but even then its the same body between the eb48.2, eb48.3, eb48sl.
I was shocked the fierce has had the proline body in stock for months, ive had friends at the track say they wish they could buy a new one, and ive told them that fierce had 3... i almost wanted to buy all 3 a few months ago and sell them on ebay... haha.
shadaloo is offline
Old 11-23-2016, 05:01 PM
  #2577
The SL body pic I seen had a shallow dip on the roof instead of hump or square
JKresty is offline
Old 11-23-2016, 05:07 PM
  #2578
What is the draw to the Proline, I like the looks of the Lead Finger Assassin
JKresty is offline
Old 11-23-2016, 05:14 PM
  #2579
shadaloo's Avatar
i have a few of the new jconcepts s1, i love em. the leadfinger is amazing too, and no reason to hunt down the proline with the leadfinger body out there.
shadaloo is offline
Old 11-24-2016, 08:45 AM
  #2580
What batteries are you running? With the SMC batteries, the S1 doesn't fit. They said it was because of the battery size.
qstorm777 is offline
