Tekno RC SCT410.3 Thread
#5177
#5178
Tech Legend
TKR1654X ? 12mm Aluminum Hex Adapters for Tekno SCT410, Slash/Stampede M6 Driveshafts and AE SC10 4×4 ? Tekno RC, LLC.
#5179
Changed my setup over to one very similar to a Ryan Lutz outdoor/indoor dirt set up ( even though I run mine on astro ) And it has totally transformed the truck.
cliche but the difference is like night and day - virtually no nose dive issue and the truck now jumps true very very similar to an 8th buggy.
On my previous setup I was struggling to clear 2 big (ish) doubles at my local 8th track and she absolutely sails over them now - very happy man, the truck just continues to put a smile on my face!!
And on a plus note - I wish I had the setup skills of the Lutz instead of having to copy other peoples, hey, who cares when it works well!
#5182
This was also on some shot schumacher mini pins so can't wait to get a fresh set of tyres then have another go.
I've gone from vented to emulsion on the shock build but had to make do filling the previous vent holes with grub screws until I get some Ali caps
I'm thinking of going down kV on mine interested in what kV people are running on larger size tracks as mine is pretty much solely used on our 8th astro tracks?
#5183
So here you would match the shock positions front and rear (Lf & RF matches, and RR and LR matches) That also goes for springs, pistons, oils, and droop. Only major thing that would change is that your rear toe matches on both sides. Once you get your base setup, you would essentially make the same changes.
But you can forget about corner changes completely. It's all F & R.
#5184
If your on FB, look in the files section of the Tekno RC Owners club group, I have a writeup in there of motor selection and gearing, with some suggestions on both, and what I found worked for me.
#5185
Coyote Hobby at that time was like carpet is was so high grip. I heard they recently have made the track more "tread friendly" so his setup is probably changed if he was running slicks before. LRH needs a rebuild soon, then it will be even higher grip then Coyote, will definitely need to get a set of Primes.
#5186
Any set ups for a medium traction,bumpy indoor track?
#5188
When you say updated kit setup, how long has this been out? I'd be interested in comparing to what I'm running at the moment.
