Hot Bodies D413 1/10 4WD Buggy
#8746
#8748
OCRC is a mid-high bite track that has some small.. hi frequency bumps where the pistons pick up the consistency...The quicker rebound seemed to help settle the suspension better across the board...especially under breaking. On my 2wd..oh boy did they make my breaking more consistent.
Didn't see a difference in jumping with the current layout. I will test again when they switch it up..could very well be the track.
I can see if the track is pretty much on an on-road track with jumps...They really wont add anything
#8749
Weird I run on a high bite clay track, seems like it jumps great, I was running them really soft at first but switched to a 40f/30r with stock springs on my 2 hole 1.6 VRP's and I love them, car is crazy predictable, reacts quickly and I feel like I can maneuver the heck out of it. Too bad you threw them away I'd have bought them from you.
#8750
Which piston from VRP are people liking? I will be running at SRS and Warehouse 3
#8752
Does anybody have a low Bite loose Dirt track set up Sheet For the HB D413 that they would like to share?
#8753
1.6 rear
I've yet to test 1.6 rear....any thoughts you can share regarding 1.6 over 1.7?
#8754
and 1.7 in the rear.
They also included a cool little piston caddy..Think of a 1" X 1" square with 4 posts on it with removable o rings inside a plastic box..Great for holding all the other pistons you might have.
miles better than some other guys that just throw pistons in a poly bag.
#8755
For the most part -
Decreases rear grip at corner exit/gives more push under power.
Less prone to bottoming out.
#8756
#8758
