TLR TEN-SCTE 2.0 Kit Thread
#9212
Simply installed the set screw into the rod ends carefully, then put threadlock on it and screw on the aluminum rod.
#9213
Yes, that is possible. It is very dependent on track and driver ability. Go to an out door track with 40ft triple and race main with 14 guys looking for the checker. If top 5 are clearing it you must do it for a shot at podium. Even a clean driver will get bumped or hit a hole you cant see sometime. On most small to medium club tracks its not much of a problem to race all season with one body and no spare parts used. The 1/8 scale tracks are not so friendly at events like AMS and others.
#9214
I just bought a new 4x4 sct troy lee ..
the both rear blue shock body has slight leak with top plastic cap. I redid again and doesnt help much. Im planning to go with Team Losi Racing Bleeder Shock Cap Set , does it fits on blue shock body (losb2826)?
THanks!
THanks!
#9215
#9221
There are a few setups posted here.
http://casper-rc.com/TLR_Ten-SCTE.htm
The new 5 hole piston setup is pretty awesome.
http://www.tlracing.com/Products/Def...odID=TLR233022
http://www.tlracing.com/Products/Def...odID=TLR233023
Ryan and I did a lot of shock testing to come up with this setup. The pistons will fit with the 22 or the stock SCTE shocks.
I am not sure I have ever tried a 2 hole piston in this truck. Due to the weight of the truck you need smaller holes to increase damping rate.
I would recommend starting with the Dunford OCRC setup near the bottom. Again setup should translate to the stock shocks quite well.
You can drill your own pistons with TLR blanks or the new 5 hole pistons should be available about the 2nd week of Sept
#9224
Another 1st and TQ and 2nd time race with my SCTE 2.0 modified ESC and battery
running with 22 shocks conversion piston F/R 2x1.3 better than stock piston that came with the 22 shocks conversion kit.
1st Losi
2nd Losi
3rd Tekno
4th Durango
1st Losi
2nd Losi
3rd Tekno
4th Durango
