TLR TEN-SCTE 2.0 Kit Thread
#8461
A few things to try:
Thinner oil in the rear diff than the front (the same oil front/rear is always too aggressive for me)
Try no sway bars - sounds crazy, but it got my truck from being on top of the track, to being "in the track".
Short Ackermann - this really smoothed out my steering high speed, especially in sweepers, but gave me more low speed mid-corner steering.
Also, a buddy of mine described my truck the same way as "being on top of the track" when he watched me run, funny you used the same description.
I recently just put the heavy sway bars on mine, I used to only run the rear sway, something I picked up on from the 1.0 to give it more steering.
I'll also look into the shorter ackerman, thanks again.
#8462
Anyone have a good, easy to drive setup? Something not as twitchy? I'm running the Dunford high bite and my rear end is loose and coming around. I am really looking for something less reactive. I havent been racing in a while and my nerves are getting the best of me, I just need to calm it down a bit.
A few things I tried yesterday were removing the rear chassis brace (i'm running the MIP's) and I swapped out the aluminum top plate for the stock plastic one.
I also used to negative expo on the steering.
Thanks in advance
Thanks in advance
Joey told me to take a shot of tequila before my rounds.
#8463
A little OT, but since you asked on FB for any recommendation for TLR products and are here often, how about a TLR pit roller bag? Anything in the works?
#8464
Thanks in advance
Thanks in advance
I forgot to mention that I did go from Suburbs (go to tire for that track) to HB Megabytes and then Blockades for the main. It helped some.
No, I havent tried either of those, thanks for the tip.
My next move was going to be taking it back to the box setup and go from there.
#8466
tore my truck apart to change the diff fluid in the front diff from 5K to 7k got to looking at everything else while I had it apart and both front inner hinge pins were bent . the one was bent so bad I had to use a pare of pliers to pull it thru the arm. I think I found my handling issue ....Well part of it any way lol
#8467
#8468
Just checking if anyone on here races at Sparks Park and if so what oils are you running in your diff.'s I know Maddog does but haven't seen him around here in awhile. Was going thru my diff's for this upcoming race this weekend and was just checking what others were doing before I got to far into it.
#8469
Just wondering what body everyone is running these days on there SCTE.
thanks.
thanks.
#8470
What size screws do I need to hold the motor mount to the motor? The 10mm ones are to long. Thanks...
#8472
I also read somewhere in this thread that one of the pro's takes his all the way in and backs it off only a few turns, making it really tight.
Past that I have also ran into this issue from running a high voltage servo and not getting enough power from the ESC's BEC. A quick fix for that is to run a glitch buster to help with burst loads needed as the battery starts to drain down. But if you really want to solve that particular issue I would suggest disconnecting the red wire from the ESC's BEC input at the Rx side and buying yourself an external BEC you can solder directly to the battery input post, then just plug it into a spare channel on your Rx.
The CC adjustable regulator version should do the trick for HV or any power hungry servos like my futaba 9352 which likes it as high as 7.4v.
Here is a link to that>
castle-creations 10 amp adjustable bec
#8475
I to had this same problem. And come to find out my servo saver had slipped back a lot. I had to thread lock the blue collar to get it to stop backing off. I would assume it works fine at first in the recommended position till it breaks in.
