Tekno SCT410 Thread
I understand the concept as follows: If you put spacer between the chassis and the mounting points (IE: under gearboxes) the effect is it'll push the chassis and all components mounted directly the the chassis closer the the ground, thereby lowering the COG.
If true, then why don't you just skip the spacers and adjust ride height to compensate?
My brain. It hurts. What am I missing?
I will ask this question here because I believe I will get a better group of answers from you guys, how much of a legit difference do you think there is between the Tenshock SC411 4600kv and the Tekin 4300HD? They are both 4 pole 550 can sensored motors, I have never ran the HD just the SC411 hoping some of you guys can give me some info. Like I said I ask here as opposed to the Tekin thread just because I know everyone here is cool and it wont be a flame war. Dont wanna start no drama just wanna know.
after reading about the spacers on BCE chassis, why nit mill the chassis higher in just those areas, kind of like putting 1mm washers in those areas, only downfall is getting dirty under there? BCE chasis are a work of art, I hadnt seen the spacers
what are they made of? delrin?
@goehm
Lowering ride height does lower CG I guess but then you are losing some of your suspension travel. It is more of how high the components are in relation to the suspension pick up points. Kind of like when manufacturers started laying servos down on the chassis to drop the CG a decade ago.
I ran the pre-production BCE chassis for a few months without the spacers and didn't have any issues with the chassis. When I put the T1-14 (production chassis) chassis in I did assemble with the spacers just because. I can't say if I noticed any change because I made multiple other changes at the same time.
I will pull the spacers half way through the day and not change setup to see if there is a noticeable difference in handling this weekend and as long as it does not take away from performance I will run it like that to stress test it and make sure there is not a durability issue without them.
I switched out my Hobbywing motor and put my BIG ol Tenshock sc411 just for kicks and I found that the extra weight that the larger motor adds is good for me, I am really able to whip through 180's a heck of a lot tighter than I was ever able to with the smaller lighter Hobbywing motor. I am also able to stay a tad more aggressive in the big sweepers with the weight I guess having me more planted and less likely to loose it and roll. So I went to the hobbywing looking to lighten and save some room but I actually do better with the heavier larger motor. I turned my fastest in race laps on Friday, 16.7 where I was more like low 17's with the Hobbywing. Crazy what works for some I guess. Food for thought.
I had a similar experience a few weeks ago I was racing and the track was particularly slick. Just dusty and it wouldn't hold any moisture or traction so all day I was searching for traction. Was struggling pretty hard and qualifying about middle of the 15 truck class. My EB48 was hooked up though and the only thing I could think was the extra weight gave it better traction. On a whim I decided to strap a 2nd battery into the truck. (two 2s 6000mah packs) It wasn't plugged in, just added a ton of weight. I had to adjust the ride height but other than that it really made the truck easy to drive. With the extra weight in the 3rd qualifier I wound up moving all the way up to qualifying 2nd overall and then got 2nd in the main by a pretty good margin over 3rd place. Only guy to beat me was the local Tekno sponsored driver who is pretty much unbeatable so I was pretty darn happy with that result.
Anyway. Lighter isn't always better IMO.
Well i have not tried out the Hobbywing motor which is lighter than the 550 Tenshock motor but the thing is with the Tenshock on the SCT Pro esc. Even if you turn down the punch control to a number (3) you cant use a 16t it just has to much amps i would know lol.
I dont know where you buy Tenshock motors really in the USA anymore.
I looked at there website they dont have them anymore it looks like. They draw to many amps anyways on the stock sct410 at least. There not bad motors though i ran my on a scte and the Mip one with a BH (copy Hobbywing esc ) and it never drawed to many amps with higher gearing.
BCE v2 Gaskets
Here are pics of the BCE v2, Rear gasket is in, mid and front are not.
(Sorry for bad pics, if you need a different angle let me know.)
Gaskets
Rear Gasket
Rear Gasket 2
Center No Gasket
Center No Gasket 2
Front No Gasket
Gaskets
Rear Gasket
Rear Gasket 2
Center No Gasket
Center No Gasket 2
Front No Gasket
You can get the Tenshocks at Express rc hobbies www.expressrchobbies.com, they still have them and that is where I got mine from. I love the way it runs paired with my RX8g2, I run a 16t with no issues. Glad I gave it a chance.
Hello SCT410 users, I just got my kit in the mail and have been working on assembling it. I got the entire front and rear together last night, but I have a couple questions
Is there a simple way to get the balls into the captured ends? I only have experience with the traxxas ends and with those I just press them onto the ball at an angle and they pop in, but trying that with these takes an insane amount of force. I got them on but they're fairly tight. Is it mandatory to trim the inside of the ends first?
Also, using the SCTE offset F11 beadlocks I have they rub on the carriers upper corners. Is this a common issue? I can file them down to clear but I'm not sure if something else is a-foot. Using the normal offset aluminum hexes (not the thicker option). I got the wheels under the assumption wheels for the SCTE work on the tekno.
I also managed to screw up the center-diff because I didn't get all the air out, but the screws thread so tight I might have to slot them to take them out, but that's totally my fault because I'm an idiot. After that first step I took to pre-threading everything before assembly so nothing else has that issue.
