Xray XB4 thread
XB4 Spur Cover
Anyone made or modified something to cover the spur gear. it sits pretty high up and worried about a cable rubbing against the gear.
pics if you have done anything
i made this exact scale replica of the xb4. i have typically seen the layout like the picture, but i am curious if there is a reason to not do the red part of the picture
Also the balanced front weight helps obtain steering.
Again you could layout your electronics as seen in your diagram. If so I would add weight by the receiver thus to offset the weight of the servo on the opposite.
Thus a balanced front end.
if you are intrested i can sent STL file for 3d printing
thats perfect. i do run a 2014.
Anyone know where I can find the rear brace to make the 2016 XB4 stiffer? Been looking everywhere but no luck.
XRAY XB4 2016 2.0mm Graphite Chassis Brace/Upper Deck (XRA361178).
I know it's an optional part but I feel like it would greatly improve handling on high bite surfaces.
The XRAY-Shop Austria has them. If not they usually always re-stock parts within 7-10 days. Shipping is pretty quick being 7-10days. You have to sign in/create an account, thus you will see the prices with out the VAT. Their parts are cheaper than purchasing in the States, however when you add shipping it pretty much equals out. Great place to go if you cant find parts in the States.
I'm sure you all are tired of this question...but here it goes...
What gearing should I start with for an XB4-16 running an 8.5 turn motor for a medium size/medium grip dirt track?
Just picked up my XB4-16 this evening!!
Regional Moderator
Jake I run 20t pinion with stock spur at RCHR with my 8.5 at 20 degrees timing and it doesnt get above 150 degrees
Quick question....
Finishing up my XB4 2016 and am at a loss of what to do about the center diff. No real experience with gear diffs so this is new to me...
I have been told/read to use everything from 50K to 120k to 1.000.000 in the center diff. Any suggestions where to start on high bite clay running slicks?
Thanks,
Aaron
Thanks,
Aaron
