Xray XB4 thread
#9076
You will experience no issue during the build.
Good tools, weight scale for diff oil. Take some time to sand shocks towers, especially front and put some cyano there to.
Everything is well explained with oil weight to put in and slipper setup.
I did soak the orings in shock oil like Bentka said and did oil each bearings with good quality bearing lube taking care to wipe any excess oil.
+1 on soaking the diff orings in shock oil, oiling the bearings and sanding and sealing the edges on the CF parts. Bentka advised me to do all of this on my 15XB4 last year and it was very helpful.
+1 with Mojo as good tools and a weight scale combined with XRAY's supreme illustrated instructions and race kits is a recipe for a very smooth and fun build.
#9077
#9078
I heard RC America received the 16 XB4 kits today as well.
Question: I heard that the 16 comes standard with the once optional graphite 2+4 satellite gears? Not positive but RC disco has them listed as a standard part for the 16 XB4.
I hope this is correct as I ran them as upgrade parts in my 15 and the were excellent.
Yes the '16 comes with the harder graphite 2+4 satellite gears
Bent
#9079
Go easy...
Basher question....
Can we put a 1/8 ESC in there with a sadlle pack configuration?
Anyone could tell me the lenght/with and high to the center brace to chassis of the xb4?
Only reason is to run a special "weird" 6s system in there... no racing or jumpin here!
Basher question....
#9080
xB4
Thank you for confirming Bentka, much appreciated.
This is good news as it saves me some $. I upgraded the F/R and Center diffs in my 15 with the 2+ 4 graphite gears and really loved how quiet, smooth and efficient they worked. I even notice lower motor temps.
I did combine the aluminum diff pins with this upgrade which I believe helped as well.
Thanks again Bentka
Thanks again Bentka
#9082
Chassis Braces on 2015
Any more reviews using the 361168 chassis braces (shorty battery) and 361173 front upper deck?
#9083
Go easy...
Basher question....
Basher question....
#9085
This is what we ran at the EUROS on medium grip clay and her XB4 was awesome.
http://forum.teamxray.com/xform/inde...setup=xb4_2015
2mm stock chassis with carbon stiffeners for the chassis braces and only the front steering brace (no top decks or 361173).
Bent
#9086
#9087
#9089
What's the space on the ESC side, then? I would like to know before i jump to a buy in a roller! I know there is the Castle Cremations MMP ESC that will handle 6s, but it's a 60 amp crematory esc...
#9090
Go easy...
Basher question....
Basher question....
Tekin RX8 is a 38 x 55.8 x 25.5mm size. Guess all are around this...
What's the space on the ESC side, then? I would like to know before i jump to a buy in a roller! I know there is the Castle Cremations MMP ESC that will handle 6s, but it's a 60 amp crematory esc…
For a '13 or '14 car running saddle packs you will just barely have the space needed for a RX8 or similar size ESC even when using a LP servo.
With a Futaba LP servo that I have here you will have 2-3 mm to spare…..but it will fit
As for the height you will have to run it without the fan and cut away the cage for the fan as well.
Good luck with the speed runs……
Bent
