SC10 4x4 Thread
#182
speaking of which, i think that happen'd to mine last night, towards the end of night on full brakes it sounded like i was skipping a tooth or 2.
#183
https://picasaweb.google.com/1113101...31478/SC104x4#
so i built some sway bars for the car, since it badly needed em. used ~2.1mm piano wire for the bars. for the links i used AE 1/10 lower shock mounts on the arms and stole the bar joints from my B44 swaybar kits. the chassis mounts for the bar were made from a sheet of ABS, i cut to the right dimensions and slotted for the bar to clamp in.
i highly recommend Chris Jarosz's setup if you run on high traction clay.
It seems to be eveything needed. I hope it works. I will let everyone know what the outcome is.
another link
http://www.tlracing.com/Products/Def...rodID=LOSA1750
Starting my build tonight
#184
#186
Going to get my truck today, and really concerned about the availability of the springs. What is everyone else doing?!? How can we race this puppy w no variation I'n spring rates?!?, Ahhhhh.....looks like the ol prolines may make a debut on first race week after all.... If you guys know where I can find the springs, plz let me know.
Also, the concepts wheels do fit? Ok, so does that mean the tense wheels fit too?
good luck to all n your builds.....and keep the great info coming. I will post as I get thru mine today/ tonight.
#187
Has anyone made a new mounting plate for the ESC, RX, and Transponder and not use the stock RX box?
I plan on doing one out of some CF plate I have so I can get the ESC back further and the RX forward more to help with not having to use a servo extension.
This way you just unplug the steering servo and unsolder or remove the motor and ALL the electronics can be removed for cleaning.
You can make flexable cover for the RX out of scrap Lexan from the bodies if you want to protect the RX, but it has not been an issue in the other 4 trucks/buggies so far.
Bob Oaks
Bob Oaks
#188
Are you putting 1 silver .030" washer on each transmission case screw? I noticed my rear transmission was tight until I put those washers on. Although it was still a bit tight to begin with after running it for 5 minutes everything freed up and rolled quite smoothly.
#189
It looks like the swaybars from my Jammin SCRT10 might fit. I get my kit tonight so I will check that out until the FT #91126 kit is available.
#190
thanks, derrick
#192
I dont know if anyone else posted this but ultimate rc has done some build videos on the truck.
http://www.youtube.com/watch?v=fjHI3QFaxQU
#193
Seeing this sway bar set makes me glad that I ordered this. http://www.amainhobbies.com/product_...i-Sway-Bar-Set
another link
another link
#194
Chris Jarosz is the man, everytime I've had an issue with any of my AE products (not many) he has been more then helpful and responds quickly...... This is another reason why I like AE rc's so much, great customer support and awesome rc's....... My build is almost done I just need to add electronics etc and will post pics once I'm done...... Man this is prob. the first time I don't think I'll need to upgrade to any rpm parts, this kit looks really strong and durable, GREAT JOB AE
#195
Woot! Just got a call that my second sc10 4x4 is in at the LHS. I was getting worried about parts for the big points series opener this weekend, but a second car should cover me.
btw, anyone else on here going to litchfield for the MORL series can feel free to use said parts car for parts.
