shocks
im also running the lane set up. thou im using 27.5 in front and 25 rear purple fr spring. orange spring rear no rebound. all i can say is its planted.
Hey guys, I will look at it more tonight. If I move the shocks to the outer location on the tower and the middle or inner location on the arms it is smooth. I will have to play around with it to get it smoother. For some reason it does not like the shocks layed over that much. I take the shocks off and it is super smooth. Brand new pins, aarms, hinge pin holders so no dirt stuck in it. I do think with the shocks layed down a little bit it is pushing out on the aarms a little causing a little bit of binding. I will figure it out tonight!!!!
Alvin,
from what I remember the Ten-T shock pistons only had 2 holes drilled all the way through.
Chris
Chris
Are the Ten T shocks and the SCTE shocks setup the same from the factory as far as the pistons go? I just built some ten t shocks emulsion style and they seem real stiff. Im using stock pistons and 30wt losi oil. I also moved the shock position to the Aaron Lane setup sheet. I have no binding at all in my arms. I also backed off the bottom shock cap a 1/4 of a turn in case the orings were sandwiched too tight. Please advise.
Thanks Chris, I will get a drill bit today. By the way I probably have 40+ packs on your pins and when I took everything apart last night they looked like brand new, the gears do to by the way Casper and Ryan and all the Losi people on here. Got my truck in the beginning of June and I believe 2nd gen. Thanks everybody and I will be getting a 28 drill bit today at lunch!
btw ChrisAttebery your pins have at least 500 packs on them by now they look as New as day I bought them THANK YOU!
Good news for all of you though.....Denial is the first step to recovery!!
Thats not the case with myself. I think I have the lightest Losi I've seen, and I race almost entirely on huge outdoor 1/8th scale oriented tracks with monster jumps. I have yet to see a situation where lighter wasn't better with this truck, but you keyboard jockeys that have never ran one this light can just keep talking.....in the meantime I'll just keep winning!!
Hey guys I have a question for you. I just put Aaron Lane's setup in the rear of the truck. While I was at it I put all new a-arms, and rear end in the truck. I have the aluminum hingepin holders and am running 1 up in front/0 rear. I put the truck back together and noticed the movement was really stiff as far as the suspension goes. It almost feels like dirt is tuck in the hinge pin holders or something. When you press down on the truck to compress it, It basically just stays there with no rebound. Yes the shocks are built correctly, orange springs, and before I put the shocks on the suspension was perfectly free as I tested the hinge pin holders and everything. The shocks are on the outside of arm/ middle on tower so they are leaned over a decent amount. Is anybody else's like this with this setup in the truck?
now this is very interesting. i always assumed the ten-t's were equivalent to a #3. i like the way my front shocks felt so i kept the ten-t pistons in the front. which size/number are they most similar or equivalent to?
hey guys i was looking on losi website and saw the lighter tuned chassis do you all think it is worth it or no
