Like Tree32Likes
Old 08-14-2013, 07:37 AM   #11851
Orion_2kTC's Avatar
I'm installing a servo and I only have 2 bolts for the servo mount...can I get away with only using two instead of 4? The servo is a KO HC RSX if that matters.
Orion_2kTC is offline   Reply With Quote
Old 08-14-2013, 07:42 AM   #11852
TAMAK's Avatar
Trader Rating: 28 (100%+)
If I "had" to I would install the top two screws. But screw assortment should be a staple in any rc racers toolbox. :http://www3.towerhobbies.com/cgi-bin...&I=LXBJSC&P=SM or http://www.amainhobbies.com/product_...FUyk4AodHmkAQg
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 08-14-2013, 08:02 AM   #11853
Orion_2kTC's Avatar
I don't disagree with you but this was a used kit and I'm still figuring out what I'm missing.
Old 08-14-2013, 09:17 AM   #11854
tiago890's Avatar
Good choice! I would make sure the car has an alloy or carbon steering link: http://www.exotekracing.com/dex210-d...steering-link/ and a BMAN rear skid for the original Dimec, if you got the type B don't worry about it... Only other must have "spares" would be a rear tower, gear cover, and pick up a hub / carrier set... I have yet to actually break anything but a rear tower and just recently a front spindle (my fault) in 2 years..
Outdoor offroad tires, always ask your local fast guys.. But you cant go wrong with a set of Proline M3 holeshots and 4 ribs.. Also, before you invest in tires / wheels. ask yourself if you want to use B4 or Durango rear wheel 12mm or 14mm hex??
DEX210 Wheels: http://www.tresrey-usa.com/tresrey-a...eel-hub-clamp/
B4 wheels on DEX210: http://www.tresrey-usa.com/yaiba-rac...rear-12mm-hex/
Hey Tamak,
Thanks, already got the RDRP steering link, would it just be best to replace the stock towers with the carbon option? or for outdoor dirt purposes would the stock plastic be best because of slight flex, as far as the tire/wheel options, what are the benefits of switching to the B4.
this is my first buggy so still learning. slightly diffrerent from the SC truck.
Thanks once again.
Sponsors: DaWife Racing and Team Myjob
tiago890 is offline   Reply With Quote
Old 08-14-2013, 10:21 AM   #11855
Orion_2kTC's Avatar
My 210 has a CF rear tower, I'm still working to get it wired up. The tower doesn't have a hole for running wiring. Can I just have the wires running over the top of the tower or will it potentially rub? Would I just be better off wiring between the shock and the tower??
Example pic: http://i.imgur.com/Mix99Yo.jpg
Old 08-14-2013, 05:35 PM   #11856
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
When in doubt, do what Jorn Neumann does... push it to the side, between the shocks and towers. Like so...
http://2wdmod.com/2013/02/01/jorns-d...edy-race-2013/
Fishhook
ewashburnaf is offline   Reply With Quote
Old 08-14-2013, 05:49 PM   #11857
aquamann's Avatar
my buggy has a rear shocktower that is the same style(no hole). I ran my wires between the tower and shocks and have never had a issue.
TD DEX408v2, tekin Rx8 gen2, tekin gen2 1900kv
aquamann is offline   Reply With Quote
Old 08-14-2013, 05:53 PM   #11858
Trader Rating: 57 (100%+)
I run my wires through the shock tower. The body definitely fits better if you don't do that though. I'll probably go back to the side when I change my motor.
shagino is offline   Reply With Quote
Old 08-15-2013, 01:54 PM   #11859
I just picked up a used one of these.
What is a good gear ratio for 13.5 blinky?
Also, what is a good , but not too expensive motor? I see a speed passion at amain for $49.99. I have run a mod hobbywing in my associated 4wd sc and it was a great motor. Are these good or was I just lucky.
thanks.
tim
Colorado On-Road RC Club
www.5280raceway.com
www.facebook.com/CORtrack
Driving: Xray T4 2015, T.O.P. Rebel 12, Durango DEX8T, Durango DEX408 v2, Associated B5M, Associated B44.2
rc_speed is offline   Reply With Quote
Old 08-15-2013, 02:11 PM   #11860
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
thanks.
tim
Speed Passion makes great stuff. You want to pick up some smaller spurs like 72-75 to gear that motor.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 08-15-2013, 03:39 PM   #11861
Dal
Dal's Avatar
Send a message via Yahoo to Dal
I have the plus 11 mm, chassis. there is no droop screw lugs, so the rear arms droop down a long way.
Rear drive shafts keep popping out.
Is there a quik fix for this.
Only thing i can think of is to put limiter's inside the rear shocks.
Any advice will be appreciated
Dal is offline   Reply With Quote
Old 08-15-2013, 03:45 PM   #11862
kwiksi's Avatar
Yep quickest solution is the limiter inside shocks...then order the droop screws that go in the arms. They will make droop setting quick and easy.
Thanks in 2017 to
Old 08-15-2013, 03:48 PM   #11863
madweazl's Avatar
You can place shims (limiters) on the shock shaft (inside the shock body) to limit down travel (between the piston and bottom of the shock body). You may be able to screw the lower eye further in which will also limit shock length.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 08-15-2013, 03:48 PM   #11864
That's actually the only solution. The RDRP chassis doesn't have droop tabs.
Old 08-15-2013, 03:55 PM   #11865
Get the long outdrives if you dont want to put limiters inside the dampers
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
