Durango DEX210 Thread >
Like Tree80Likes
Old 07-25-2013, 02:58 PM
  #11731
Hazzmatt1's Avatar
Questions?? Shock Oil
Sooooooooooo I'm changing my shock oil to 40w however the only oil I had was from my HPI 5SC 1/5.
The oil is petro vs sillycone...............QUESTION is what is the difference going to be??????
Matt
Hazzmatt1 is offline
Old 07-26-2013, 02:25 AM
  #11732
madweazl's Avatar
Matt
I'm not familiar with the oil in question but there are typically do different standards, CST and WT. There is a bit of variation between the two standards and another slight difference between manufacturers with the same standard (ie Associated oil may not be the same viscosity as Losi). I guess in reality, WT isnt a standard unit of measurement but that opens another can of worms.
madweazl is offline
Old 07-26-2013, 05:49 AM
  #11733
McD44's Avatar
Trader Rating: 16 (100%+)
Matt
Your o-rings may swell. I can't say with certainty but it is a possibility.
McD44 is offline
Old 07-27-2013, 04:50 AM
  #11734
cyclone's Avatar
thanks for your help on here guys its really useful!
My latest problem I'm finding is the ball is popping off the bottom of the front shocks and making the car feel strange in most runs, i don't want to have to buy new ball parts (or shock ends) though, is there another solution to prevent this? I tried it with the ball piece in both ways round and the problem was least bad in this position.
THanks!
cyclone is offline
Old 07-27-2013, 04:58 AM
  #11735
McD44's Avatar
Your only real solution is new shock ends. Yours is worn to a point where that will keep happening no matter what.
McD44 is offline
Old 07-27-2013, 11:07 AM
  #11736
Trader Rating: 2 (75%+)
Got a question for you guys running the B Fast diff kit in your durango. I ordered the Pro Drivers kit with the rings.carbide balls, and ceramic thrust bearing. Here is the problem. The balls that come with the kit are bigger than the balls in the stock durango thrust. Also if you try and use the washers and balls that come in the B Fast kit they aren't as thick as the stock durango thrust therefore the c clip won't hold it tight. Any ideas?
durangoman is offline
Old 07-27-2013, 12:49 PM
  #11737
Bigrigger's Avatar
Awesome. I just ordered the exact same thing.
Bigrigger is offline
Old 07-27-2013, 02:20 PM
  #11738
Lol tell me about it.
Old 07-27-2013, 02:27 PM
  #11739
RC10Nick's Avatar
have you tried contacting bfast? Maybe it's a mix up in the order? Can't imagine they'd sell something that didn't fit.
RC10Nick is offline
Old 07-27-2013, 02:47 PM
  #11740
Yes i was told to use the one that comes in the kit. That is my problem.
Old 07-27-2013, 07:28 PM
  #11741
Trader Rating: 19 (100%+)
It works perfectly fine, I've built a few and never had an issue with the B Fast thrust. The diff bolt with draw the thrust assembly tight against the circlip (just as the stock one does) when you tighten the diff halves together. No cause for concern there.
Jonny5 is offline
Old 07-27-2013, 08:05 PM
  #11742
Thanks Jonny5. That is all i needed to know.
Old 07-27-2013, 08:28 PM
  #11743
platgof's Avatar
I personally like the Acer carbide bearings, work great. Had a great night racing and took 3rd in the main, and had a first in the second heat. Starting to get the hang of it. I am running the rear shock setup.
platgof is offline
Old 07-28-2013, 06:13 AM
  #11744
Brownie.'s Avatar
Does anyone else have issues with their 210's jumping inconsistently? No matter what I try I keep ending up on my lid. Ive tried other brands of car on the same track and have no issues with the jumps. Just the 210.
Brownie. is offline
Old 07-28-2013, 06:33 AM
  #11745
RC10Nick's Avatar
What pistons are you using? My car jumped much better after I switched from the kit 6 hole to a 4 hole.
RC10Nick is offline
