Durango DEX210 Thread
#3046
Also, is anyone having issues with the one wheel getting full lock and the other not? My left wheel turns left more than the right wheel turns right. I've tired messing with the whole front end and still can't get either side to even out.
#3047
Have a look and make sure that you have the same inserts trailing etc on both sides
You don't mean when you turn left the LHS turns more than the RHS?
Or do you mean that when you turn L the LHS truns less than the RHS
When you turn L It should seem like the RHS turns more and turn R the LSH should seem to turn more
confused much I am a little now
#3048
Location: Proper beer garden over looking the beach :-)
Here's me ride. So does anyone know where I can get black & white stickers done? (& not the rc wrap type, but the type that come in the rc kits)
Cheers!
Cheers!
#3049
#3050
#3051
Had a GREAt time with my DEX210 on Friday Night..... Seemed Dialed so Far
I face planted in the main... but for my 2nd race day in almost a YEAR... I am pretty happy with my progression so Far....
Hey Chance/Chizzle... hook a BRUTHA up on yer setup at whse 3
Stav
Stav
#3052
Merry Christmas to the DEX210 crew!
#3057
One of your turnbuckles is probably longer than the other. Best way to set up steering is zero out your radio trim, place the servo arm on the servo as close to center as possible, then install equal length turnbuckles, adjust steering trim on your radio so wheels are equally "balanced" (whether they're way toe out or in as long as they're the same), now adjust your turnbuckles to where you want your toe. This allows each turnbuckle to be the same length, which is what you want. Now, if you have the capability, adjust your individual end points so the servo doesn't over extend.
#3059
- set the controll links and servo arm at correct lengths and angles.
- set the endpoints on your radio.
Finished
