Durango DEX210 Thread
#3796
I want to get me a few different springs for my 210.
but the full size spring sets are just to expensive , mostly because I will just use 1 or 2 different spring rates.
Im the only durango driver at our track, so I cant ask someone else.
my track is outdoors clay, sometimes wet conditions somtimes dry and dusty
I will run my dex 99% of the time in RM3 modus with heavy fullsize stickpacks
race weight is between 1650 grams and 1710 grams
what spring rates are a good option for me ?
#3797
For those of you that pre-ordered the RCshox GBX (gear box fix) i just finished all 60 of them and they will go out late today early tomorrow! thanx for the order and enjoy! On a side note we had a big series race this past saturday that was 80% 1/8 scale. I practiced on the track through about 5 4800mah packs tangling with the eighth and SC trucks, flipping ,tumbling and anything inbetween with no failures and a few times i just knew it would break but it didnt! So drive with confidence, it aint gonna break!!
#3798
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
Been following the thread for a bit and I dont remember seeing this info posted. To run RB5 R wheels and have the correct offset you need the 12mmhexes and drive pins for the losi XXX-SCT.1 shim between the hex and the bearing,just barely ream out the axle hole in the RB5 wheel to fit over the shaft and bolt it in place.Good to know if you have a bunch of mounted rubber for an RB5
#3799
For sale
I have my 210 posted in the for sale section here
I love this buggy and it is dialed, but I bought a 22T and want to be able to carry spares that will work for the truck and a 22 (that I have as a trade option for the 210).
Let me know if there is any interest - If you buy it for cash, mention you saw it in this thread and I will cover the priority shipping.
#3802
Yes, you are indeed correct.. But because I'm human, I have difficulty nailing this technique time and time again, especially under pressure.
What I have found helps is, if you add a reasonable amount of drag brake, you can basically go back the same style you were doing with RM3.
#3803
take the shock shaft out and put it in thru the bottom and see if its your orings. mine had alot of res also even with new greased orings and oil on the shaft. we had the same issue with the losi 22 so i used 1 dur. oring and 1 black low res. losi oring = WAY MORE GOODER! put the stock durango oring in first, if you go with 2 losi black orings the shock will have some leakage and you'll need to keep an eye on them.
#3804
#3805
#3806
how does the dex210 compare to a kyosho rb5 sp2? Thinking about switching. I don't like the way the rb5 pushes on corner exit.
#3807
A shameless plug for my 210 that is for sale too!)
#3808
I have never had a car with more on power steering. It almost feels like you could screw it into the ground on corner exit. I am sure others will say the same thing.
#3809
#3810
Along the same line of thinking- I sand just a little bit off of the plastic spacer between the orings before initial assembly. This keeps the orings from getting compressed when the bottom cap is tightened down and eliminates some friction in there. The orings are not meant to be compressed to seal nicely, so if they are squeezed at all they tighten up on the shafts. Something a fellow racer showed me on the ae shocks and I now do it on every set of new shocks I build.
