Team Associated B74.2 / B74.2D
#421
I'm just speculating, but that's probably why they elected to call it the 74.2CE vs. 74.3 or 84...
#422
What does the b74.2d weigh stock, ready to run? I know specific components can change the weight significantly, but just interested to see what you guys are seeing before you put the cars on a Weight Watchers diet.
My current car is 200g over the minimum and I am looking to get something a bit closer to the minimum.
TIA
TIA
#425
#426
Are the 4.75x8mm Titanium Ball Studs the correct size for the car? I know the length varies the 4.75 is what I’m wondering about.
#428
1mm shims under C and D blocks?
I’ve been looking through the recent setup sheets that have been posted for high grip dirt tracks. One thing I’ve noticed is that they are placing 1mm shims under the C and D block. Does anyone have a picture of what this might look like?
#431
It’s just what it sounds like: 1 mm shims between the chassis plate and those blocks to raise the hinge pins. It raises the roll center quite a bit which may be necessary when running low ride heights.
#432
But I've also ran it in stock, but that was more so because all I had time for was the motor swap, then later I took it off for a qualifier. It seemed to pickup some pace but with my lack of track time on that layout it could be me just learning the layout. But it was a very small dirt track I was on. I think the washer support the rear end more, but slow the movement down at the same time. So for mod you can just give it more power, while in stock not so much. If MattyG told me its slower in stock- Id believe him.
