12th Scale Racing is Alive and Well in So Cal
12th Scale Racing is Alive and Well Worldwide
Ok Racers here it is.
A compiled list of information, and links to help guide you on your quest to build and race 12th scale.
Tips & Tricks of 12th scale tuning
12th Scale Tires Made Simple (Sort-of) by Christian Tabush
On-Point Racing - '12th scale Pro Tips' Part 1
On-Point Racing - '12th scale Pro Tips' Part 2
On-Point Racing - '12th scale Pro Tips' Part 3
R/C Car Handling website; Everything you need to know about vehicle dynamics
Pod Droop vs Chassis Sag - Bruce Carbone -
Gear Rollout Chart
Spur Gear calculator
Setup Sheet Database
Setup & Build Tips by Andy Griffiths
How to extend the life of your tires
How to build a Ball DIfferential, by Dave Irrgang (IRS)
How To Solder Correctly
Xenon Rollout Sheet
Wheel spec chart (credit to kimihiko-yano.net)
Motherload of RC setup, building, etc, answers to everything one could want to know, compiled by Arno at petit RC
Edwards setup & tutorial videos
12th Scale Forums
12th Scale Thread
Classic 12th scale
How to mount a 12th scale body
Ok, now this is the fun part, where you get to pick out your favorite new kit
Colors optional
_______________________________________________
Team Associated RC12R5.2
Team AE Forum
Volker Worlds Setup Sheet
Howhart Worlds Setup Sheet
________________________________________________
CORALLY 12SLX
Corally Forum
"CRC Xti-WC"
CRC Forum
Kyosho Plazma 1/12th
Kyosho Forum
Plazma LM Series
On Point 1/12 Conversion Kit
RSD RR12
RSD RR12 Forum
Roche Rapide P12
Schumacher SupaStox GT12
RCTech Forum
Team SpeedMerchant
SpeedMerchant REV8-Pro
Serpent S120LTR
Serpent LTR Forum
Tamiya RM-01
Tamiya RM-01 Forum
Setup Info
T.O.P Rebel 12
Top Racing USA
Top Racing Forum
VBC Lightning 12
VBC L12 Forum
X12-15
XRAY XII-15 Forum
Yokomo R12C3.1
Mark Payne R12C3 Knowledge Base
R12C Build article
Yokomo Forum
The Zen-RS conversion for the Associated R5
Popular Electronics, Servos, Speed Controls, Accessories & Information for 1s Racing
TQ Racing Wire14g - 16g
Boost=electronic timing advance, this is the most efficient way to drive a brushless motor, the timing is applied incrementally to keep peak performance from 0 rpm to max rev limit, the issue here is that a 17.5 motor for instance, is now as quick as a 13.5 motor for 1s, and more like a mild mod motor with 2s.
Timing= a mechanical adjustment to the endbell of a motor like in the brushed motors of days gone by. This method of timing advance will also increase performance to a point, but in doing so the motor will produce more heat, and reduce durability over time.
Blinky mode refers to no electronic timing advance.
Open esc = boosted, or modified.
Airtronics (Sanwa) Super Vortex Zero 1S ESC
G Force 1s 120A
HobbyWing
XERUN 120A 1S V3.1
Setup info
LRP
SXX Comp VII
Reedy BlackBox
Discussion thread
ORCA VX 1s
Team Orion Vortex 1s
SpeedPassion Reventon Pro 1.1 EX
Viper VTX1
Novak 1S Lipo Booster
LRP-X 12 series timing info
4-dot = 27.5°
3-dot = 32.5°
2-dot = 37.5°
1-dot = 42.5°
0-dot = 47.5°
You read the timing with the dots facing you.
Reto Koenig
LRP electronic GmbH / Germany
Futaba
Digital Brushless
BLS 651
Digital
S9650
Analog
S9602
JR
Z3650
KO Propo
PDS-951
Spectrum H5020G
Tire & Tools
John's BSR Tires
Pro One R/C Wheels
Pro One R/C introduces the new Pro12 wheels. These 1/12 wheels offer a unique offset which enables the car to have faster corner speed and better handling.
Ultimate Tires
Every tire is sorted for it's hardness using a duromenter and measured in three points for accuracy.
Materials are top quality and in optimal conditions from manufacturing until you open the resealable bag.
The carbon rim provides ultra lightness, massive strength and extreme precise accuracy.
Developed and made in Japan
Mobgum Tire Truer Wheel Support
And here is a an easy to use Tyre Truer-Adpater from the good folks at CRC
Ultimate Tire Grinding Tool from C.Andy's RC Prototypes in Germany
Team Tamale Tire Truing Adapter
Yokomo Foam Tire Glue video blog
Gear Rollout Chart
Xenon Rollout Sheet
12th Scale Forums
12th Scale Thread
Classic 12th scale
Colors optional
Team AE Forum
CORALLY 12SLX
Corally Forum
"CRC Xti-WC"
CRC Forum
Kyosho Forum
Plazma LM Series
RSD RR12
RSD RR12 Forum
Roche Rapide P12
RCTech Forum
Team SpeedMerchant
Serpent S120LTR
Serpent LTR Forum
Tamiya RM-01
Tamiya RM-01 Forum
Setup Info
T.O.P Rebel 12
Top Racing USA
Top Racing Forum
VBC Lightning 12
VBC L12 Forum
X12-15
XRAY XII-15 Forum
Yokomo R12C3.1
R12C Build article
Yokomo Forum
G Force 1s 120A
HobbyWing
XERUN 120A 1S V3.1
Setup info
LRP
SXX Comp VII
Reedy BlackBox
Discussion thread
ORCA VX 1s
Viper VTX1
4-dot = 27.5°
3-dot = 32.5°
2-dot = 37.5°
1-dot = 42.5°
0-dot = 47.5°
Reto Koenig
Futaba
Digital Brushless
BLS 651
Digital
S9650
Analog
S9602
JR
Z3650
KO Propo
PDS-951
Spectrum H5020G
Tire & Tools
John's BSR Tires
Pro One R/C Wheels
Ultimate Tires
+ YouTube Video | |
Last edited by RedBullFiXX; 08-23-2016 at 11:27 AM. Reason: Work in progress, send pm or post here if you don't see what you are looking for.
Trader Rating: 25 (100%+)
I LOVE 1/12 scale and will be looking to race it!! I have a prior committment for the end of April however. I WOULD like to race 1/12 scale on Wednesday nights at TQ if we can get some guys to go there. I know Tony Neisenger may be available at TQ Wed's. I'm IN---just ordered my 1/12 lipo battery so I can use the Tekin in my 1/12 scale car. I think I was the ONLY 1/12 in the A main without the "magic esc" and it really hurt on the long sweepers and back straight. Maybe Eric P could be up for Wed nights on the carpet?? I'd love to race these babies and will be prepared to do so by next week.
FWIW
Tim
FWIW
Tim
FWIW
Tim
FWIW
Tim
Hope to see more 12 racers at TQ.
FWIW
Tim
FWIW
Tim
Some of us were talking of maybe a 10.5 class. Something fast and fun for club racing on the ultra stuck carpet. Anyone interested?
Everyone already has 13.5 motors--and with the Tekin RS or PRo esc--their plenty fast. they were doing low 9 second laps at TQ--with a little more time--I"m sure they will be in the 8's. That's quicker than the 4 wheel drive sedan cars were going isn't it? Should be plenty fast enough for a lot of fun/tight racing.
Let's see if we can get all the 1/12 cars to come out on Wed nights or Saturdays.
T
T
I’ll be there and I’ll have my cars with me. This is going to be my first club race. So far I have only worked on my TC car at the Tamiya track on Saturdays. My 12r5 has been seating on the shelf since I put it together. Whit some help from the experienced guys I would love to get the 1/12th scale going too.
Tigran
Tigran
I was completely out of power in the last minute.....
Anyways, my magic ESC is in the mail....
I think that running 10.5 with magic ESC will make the racing so good and fast (I think that will be the same as running any mod motor), we have to take the advantage that we have a track that is capable of handling the speed of this little cars....
[QUOTE=RAL;7235304]TQ wasnt using a "magic esc"
I qualified 4th and finished 3rd in 17.5 with a GTB on a 1 cell. It was down on power but still competative? RS will be in next race.
