Old 10-07-2014, 10:01 PM   #1
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default Reedy BlackBox 1s 2s ESC
Impressive features
Blackbox 410R 1S-2S Competition ESC w/PROgrammer
Part #27001
The long-anticipated and highly developed Reedy Blackbox 410R ESC is now available to racers worldwide. Extensive track testing by Reedy’s engineers and racing team has resulted in a high performance, high quality, and reliable ESC suitable for all levels of competition. A focus on excellent throttle and brake feel, precision adjustability, and robust hardware make the Blackbox 410R suitable for a wide range of racing applications.
Features
• CNC-machined black aluminum case with integrated heat sink
• Fully adjustable brake, throttle, power, and safety functions
• Eight pre-programmed, customizable* profiles
• Blinky mode with ROAR-approved software
• Precision throttle and brake control
• Speed sensitive drag brake function
• Ultra-low resistance FET board
• 12-gauge power wires
• Heavy-duty external capacitor board
• Built-in voltage booster for 1S applications
• RPM data logging*
• Firmware updateable*
*Requires Blackbox PROgrammer #27020
Specifications, Blackbox 410R
Voltage input 3.7 - 7.4 / 1-2 LiPo
On resistance (ohms) 0.00035 x2
Continuous current (A) 150
Dimensions (mm) 40.8 x 33.0 x 19.0
Weight w/o wires (g) 49
Motor limit (2-pole/4-pole) 3.5 / 4800kV
SBEC 5.5 - 7.0V/5A
Cooling fan optional
With the Blackbox PROgrammer, the full potential of the ESC can be exploited. In addition to working as a programming device to fine-tune the eight pre-installed profiles, the PROgrammer operates as a data logger, battery monitor, and USB firmware update device.
Brake
Brake strength, frequency, curve, and drag brake can be fine tuned to change brake performance and feel in different vehicles and track conditions. The Speed Sensitive Drag Brake function allows for different drag brake settings and high and low speeds.
Throttle
Frequency, punch, curve, and dead band make the perfect setup possible regardless of the type of motor chosen and the type of vehicle being raced.
Motor Power
Advanced acceleration boost and top speed timing settings are particularly useful on large tracks in applications such as 1/12 and 1/10 Touring Car and stock classes where ESC timing is permitted. Each setting can be used individually or together to achieve maximum speed. If you choose to leave these settings disabled, the ESC will be operating as if it is in blinky mode.
Miscellaneous Control
Select between open, blinky, and practice modes depending upon the class being raced. Adjust the SBEC voltage to change servo speeds. Forward and reverse power can also be changed.
Protection
Select the desired low voltage cutoff or disable it completely. The temperature at which the ESC cuts motor power due to overheating can also be adjusted.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-08-2014, 12:18 AM   #2
racer x 1's Avatar
Trader Rating: 27 (100%+)
great looking esc. I feel like it may be a loose spin off of the hobbywing stuff, although thats not a bad thing . other than that the size does concern me for 1/12 stuff. On another note I have seen the ae off road folks running these for a while without issues. any idea on the price point?
Matt Bell
Mugen MRX5 • Ae R5.2 • X6^3 • M11x • All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 10-08-2014, 02:24 AM   #3
definitely looks Hobbywing(ish)
more like the Orion R10.1 with the wires to the rear as opposed to side on.
7.0V/5A BEC is nice!
cplus is offline   Reply With Quote
Old 10-08-2014, 07:42 AM   #4
patorz31's Avatar
The Programmer looks very "Viperish.."
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is offline   Reply With Quote
Old 10-08-2014, 08:24 AM   #5
Castradamus's Avatar
Trader Rating: 53 (100%+)
This looks really promising. I like that you can use if for 1S and 2S racing. I wish manufactures would go away for programming boxes all together. I wish they would lean more towards IOS and Android interfaces. That way you don't need to have a laptop at all. The program boxes usually need firmware upgrades so you are not eliminating the need of the laptop just reducing the time I have to use it.
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 10-08-2014, 04:25 PM   #6
Scott B's Avatar
Trader Rating: 43 (100%+)
Looks similar to the SMC esc...
And Rick said before it was not made by hobbywing...
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 10-15-2014, 10:03 AM   #7
jetnjme's Avatar
Talking
230 with programmer. need to sell of my rental properties just to fund my rc habit
Nor Cal Pan Car
Northern California Pan Car Revival
jetnjme is offline   Reply With Quote
Old 10-15-2014, 01:29 PM   #8
OSherman's Avatar
definitely on my to-do list..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 10-15-2014, 04:57 PM   #9
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I'm pretty sure someone from Reedy already revealed earlier in another thread(unofficially?) that the ESC is OEM by Viper but it is the software that is exclusively Reedy which is the only basic difference between any and all speed controls of similar spec.
Racing4Evo is offline   Reply With Quote
Old 02-24-2015, 03:38 PM   #10
AE-Reedy
Wanted to let everyone know we have finally been given ROAR zero timing approval.
Sean Cochran is offline   Reply With Quote
Old 02-24-2015, 09:56 PM   #11
why does it not come with a fan?
fuse01 is offline   Reply With Quote
Old 02-24-2015, 10:03 PM   #12
patorz31's Avatar
Cause if it is viper internals it wint need one.
Old 02-24-2015, 11:28 PM   #13
malcnz's Avatar
sorry to say but it does...friend got his last weekend for our Nats and kept over heating in Mod and shutting down and once he hooked a fan up to it(not the factory fan as not available) the overheating issue went away.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 02-25-2015, 12:43 PM   #14
AE-Reedy
Mod TC is the one class that might need a fan.
We can also provide an updated firmware that has the ESC temp adjusted we think the original firmware is too sensitive to temperature, meaning it turns off the speed control at too low a temp.
We are trying to get the website working to provide these items but we are having issues with the webmaster.
Please contact us by email and we can try to get you sorted.
[email protected]
Old 02-25-2015, 12:56 PM   #15
malcnz's Avatar
[email protected]
Thanks Sean..will pass that on...I know the guy got prity frustrated with it as tryed to reset the temp cutoff but couldnt.
also he ended up breaking the sensor lead as it needs to come off everytime you make changes which eventually caused the small little wires to break..maybe something to look at as others go thru the wire from the speedi.
also the sensor wire is female/female? or female/male so not compatible with other motors..something like that he mentioned.
