Old 12-27-2011, 09:40 PM   #1
For_the_win's Avatar
Default How to mount a 1/12 scale body.
Any one have any tips or tricks on how to mount one? I just did my first one and im afraid the body is to far forward so when i turn the wheel are going to hit, I dont wanna buy another one and mess it up again.
For_the_win is offline   Reply With Quote
Old 12-27-2011, 09:57 PM   #2
Put white out on the tip were u clip in the body place the new body over so it leaves a white mark where it needs to be cut so the body fits snug and accurately . Works for me
silentek is offline   Reply With Quote
Old 12-27-2011, 10:11 PM   #3
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
i mount the body before i paint it... cut out the front wheel holes and match them to the front wheels. then i mark where the body posts are from above/outside. then i mark the centers for the 2 back wheels and use a circular cutter to cut the holes out.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-27-2011, 10:29 PM   #4
I have a rather elaborate way of doing it but it works well for me.
1) Mount body before painting
2) Draw a vertical center line of the front wheel wells
3) Setup the car with equal toe L/R
4) Space out all the wheels until they are just slightly wider than the body
5) Turn on the car, lower the body over the car and line up the front axle with the front wheel well center line
6) Mark the body post holes
That is essentially it. There are a couple other things I do to make it easier that other people will find tedious. One such thing is I use aluminum stand offs instead of body posts and make sure they hold the body up at the right heights. This is because body posts get bent up so I want to make sure I use something perfectly straight to get the holes right. That way when I replace the body posts the body isn't crooked.
Old 12-28-2011, 01:37 AM   #5
you always need to mark from the outside the bodypost placement with the alignment of the front wheels, the rear are to some extent a little less important (there is usually enough room to cut more forward or rearward)
Then paint your bodyshell leave it to dry a full day and cut the wheelarches with a rounded scissors.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 12-28-2011, 02:31 AM   #6
wingman2's Avatar
I put the chassis on a setup board, and then use a combination of the lines on the board, and the chassis itself to get the shell in the correct position. Cut the excess from around the shell with a brand new scalpel blade, then mark out the body posts and roll over mount. Once that is done, mark the front/rear axle points on the shell and then use a composs cutter to get perfectly round arches. Last thing to do is to put a A4 sized peice of sandpaper on the setup board and rub the bottom edge of the shell against it so that it is flat! Then, clean it properly and it is ready for painting! Cheers, Chris.
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 12-28-2011, 09:09 AM   #7
damn so i guess i should have waited then, i mounted it without any wheels on it. Great i just ruined, my first awesome paint job
Old 12-28-2011, 10:19 AM   #8
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default How to mount a 12th scale body
Hey guys.
Some great tips in here.
I'm going to link this page to the 12th scale thread.
Here
12th Scale Racing is Alive and Well.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-28-2011, 10:44 AM   #9
Originally Posted by RedBullFiXX View Post
Hey guys.
Here
Sweet thanks, i searched the forum for a bit and found nothing i like the tip in here they will do nicely!
Old 12-28-2011, 11:06 AM   #10
samshirley00's Avatar
when I mount a body, i have some old body mounts, i have cut down so they will fit under the body, so when i have finished cutting it, i can clearly see where they will come up, and 9 times out of 10, it is perfect
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 12-28-2011, 11:09 AM   #11
Timbulb's Avatar
+1 Always do it this way and it always worked. If I screw up and forgetto cut the post holes before I paint it, I use a paint pen like the guy who uses white out.
PS: Am I the only one who sees the irony in the O.P.'s screen name?
Timbulb is offline   Reply With Quote
Old 12-28-2011, 12:08 PM   #12
Shhhhhhhhhhh, no one has noticed!!!
Old 12-28-2011, 09:59 PM   #13
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Same goes. Old short body posts and a Sharpe. Dot where the body post center is when tires are where you want them and your gold (before you paint). Pre outline with Sharpe the wheels too (before you paint). Better luck next time! Sorry
Josh-n-ya is offline   Reply With Quote
Old 12-29-2011, 09:35 AM   #14
OleC's Avatar
http://www.redrc.net/2010/10/pit-sha...mounting-tool/
OleC is offline   Reply With Quote
Old 12-29-2011, 12:15 PM   #15
1/12 forum ovalnator Electric On-Road 46188 Yesterday 08:58 PM
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
FS: 1/8 Scale Ofna Colt, Starter Box, JR XR3 FM Radio Tons of Parts Platinum_Racing R/C Items: For Sale/Trade 10 07-09-2006 07:15 PM
looking for a 1/12th tnt2671 R/C Items: Wanted to Buy 12 12-19-2003 10:11 AM
