1:10TH EP Onroad Setups & Discussions
#16
#17
Can some one put up a link for a t2009 set up sheet for sma. Cheers i really dont no were to start its my first rc car. I need to by some pinion and spur gear sets what be some good combinations to buy i have a 21.5 motor and lrp sphere tc spec esc ill be racing at sma and windsor thanks for any help you can pass my way ...
CHEERS CAINO
CHEERS CAINO
#20
Still chasing my setup a little but here is what I have started with.
http://forum.teamxray.com/xform/inde...4&setup=t2_007
#21
Mark Wallin
EPIC (Mallee and Coorong)
XRAY T2009
http://forum.teamxray.com/xform/inde...0&setup=t2_008
Any one looking for a foam/carpet setup for the T2 should find this interesting.
XRAY T2009
#25
#27
raced at tempe (SMA) on sunday and found the track a bit off even with my usual setup on my T3. Tried muchmore blue gap and cook it in but still was a bit skatey on power so one of my friends suggested trying, was bring the rear sway bar arms out on the outer ball on the rear arm. i tried that and it made a big difference.
Thought i might post it up because ive never tried it and it made a marginal difference so if your looking for that little bit more in the rear give it a go.
boothy
boothy
#28
Mark Wallin
Windsor
XRAY T3
http://forum.teamxray.com/xform/inde...=1591&setup=t3
I came up with this for my last run of the day thanks to some advice from regular Windsor runners so I'm sure there is more to come. Any one looking for a starting point though will find this usefull.
T2 '009 settings to come.
Windsor
XRAY T3
#29
Shock Rebound %
Which Topdeck Standard or Ashphalt
Did you run the lipo weights set (60g) and which weights if any did you use to balance the car on each corner
Cheers
Adrian
#30
Ive found the Asphalt top deck gives me more steering without unsettling the car. Ive got the L shaped holders on from the lipo weight set to secure the lipos in also using the standard T and L shape batter holder on the inside to also secure the lipo, Ive got no weights on the car as without them it already weighs over the minimum 1425g.
Now remember, for me this setup work well with the Muchmore tires which gives a little more overseer than others which I like, if I was to use sorex or similar removing a couple of the front topdeck screws can give a similar feel as using the MM tires and or leaning the front shock down 1 hole.
