Toys for Tots Championship at R/C Raceway
#151
Had a good time yesterday, I'll have to come out again sometime when I have more than just clay tires with me. That way I can go strait to the A-main instead of bumping out of the C...lol.
Even with other guys running open and lower turn motors, I never really felt like I was underpowered. My problem was in the tires, not the motor. If anything you could leave the 17.5 in and switch to a boosted profile, but there wasnt enough of a backstrait for it to matter really.
#152
#154
Cole and I had a blast Sunday. Another great event at R/C Raceway. Thanks Guys.
Thanks Howard for the vids.
#160
I think the strongest reason for it being open is to welcome the RTR guys. With the size of the track and current conditions, anything more than 17.5 is overall a disadvantage. I think a 17.5 with just a little bit of boost would be perfect. My son and I still run the RTR electronics which is a 3300kv motor. We have it geared 15/87 with the EPA set at 90% and it was still too much power. The only issue I have with running 17.5 is the cost of buying an ESC and motor x 2.
#162
No, I was 3rd. I'm still fighting the rear traction issue but it is better. As usual, my traction / grip went down throughout the day. I'm thinking I should try going back to a full size battery for more weight. Softer springs are helping but I am at the softest that I have and there is only 1 step softer available by AE. Maybe some more weight will be similar to softer suspension.
#163
#164
Sounds like it was a great time. I had really hoped to be there but I felt like poop all day Saturday at the Leisure and decided it would be best to get a good day of rest instead. Dang it. Next time I guess.
#165
Usually a problem like this comes down to very small changes. As the day goes on add more rear camber and take some front out, raise the front ride height and/or lower the rear by a half turn of the shock collars, add a ballstud washer before the main, move the wing back just a little (tlr has multiple holes for a reason and it works).
This stuff will usually keep the car feeling very similar from the start to the end of a race day when the track is drying out.
