Go Back  R/C Tech Forums > North American Regional Forums > Wisconsin & Illinois Racing
Off-Road Racing @ Leisure Hours Raceway >
Like Tree1Likes
Old 03-17-2012, 09:39 PM
  #31
Originally Posted by SloMoFo
What type of tires should I be looking for, racing blinky and mod short course.
Oh yeah, for outside.
Green double dees were real good.
slowguy2012 is offline
Old 03-17-2012, 10:07 PM
  #32
Trader Rating: 19 (100%+)
In stock last year I ran green carvers up front and m4 holeshots in the back. Gridirons are good too as are enduros. Watch out for excessive tire wear if you have a lot of motor or a heavy throttle finger.
Jonny5 is offline
Old 03-18-2012, 07:32 AM
  #33
mjk1210's Avatar
I think enduros are consistently the best tire outside. Double dees were real good but could get a little too loose at times. Enduros have a bigger square lug and have real good forward bite and sidebite without catching an edge and making the truck flip over too easy.
mjk1210 is offline
Old 03-18-2012, 08:56 AM
  #34
hotrodchevy14's Avatar
Trader Rating: 115 (100%+)
get all lh threads ttt
hotrodchevy14 is offline
Old 03-18-2012, 10:24 AM
  #35
1mrdad's Avatar
Trader Rating: 48 (100%+)
What kind of outdoor tires do you recommend for 1/10th buggy, blinky and mod?
1mrdad is offline
Old 03-18-2012, 01:43 PM
  #36
SloMoFo's Avatar
Do the tires burn up more quickly outside than inside? They seem to last some time inside, after the first few runs there is a little wear, but not much after that. I have been running Switch 2.0 and Rattlers.
SloMoFo is offline
Old 03-18-2012, 05:35 PM
  #37
They can, but don't have to. I ran the same set of tires all season last year on my stock sc. Cush burned up a set of rear Enduros in a day one time running mod sc. Compound, throttle control, available power, and traction (moisture) all effect tire wear.
Jonny5 is offline
Old 03-18-2012, 07:55 PM
  #38
Red ifmar pins were best for me last year, but tend to wear quickly, usually gone in one day if dry. Red ifmar studs held up longer and were still quick. Losi 7202r up front, stock foams all around.
jsorwell is offline
Old 03-18-2012, 08:26 PM
  #39
mjk1210's Avatar
They watered the track most rounds last year which kept tire wear down most of the season. The first 5 weeks i think i ran one set of ifmar pins. If u want the best combo of traction and wear get losi red ifmar studs for the rear.
mjk1210 is offline
Old 03-18-2012, 08:51 PM
  #40
jsmccallum's Avatar
Trader Rating: 16 (100%+)
... stock foams all around.
That reminds me of a question I had--how do you guys think about foams in general? For example, for 2wd buggy, how do rear closed cell foams perform relative to stock?
jsmccallum is offline
Old 03-18-2012, 09:08 PM
  #41
I have always treated them like air pressure in a tire- in high traction a firm foam will generally yield better traction and feel, in low traction a softer foam will help with traction at the expense of feel. For 2wd classes I run either a stock open cell or a Trinity Bomb one foam outside. In 4wd sc I'll mix and match closed cell and Bomb one foams front and rear depending on what the truck needs.
Jonny5 is offline
Old 03-18-2012, 09:50 PM
  #42
mike nelson's Avatar
Default 3/18/12 results
Thanks to everyone who came out to run the points series today, tough decision when its so nice out in March! Here are results from today.
File Type: pdf
mike nelson is offline
Old 03-18-2012, 11:01 PM
  #43
aptyk88's Avatar
Trader Rating: 44 (100%+)
is the outdoor track ready?
aptyk88 is offline
Old 03-19-2012, 05:19 AM
  #44
No.It will be a few weeks
Bubba Cola is offline
Old 03-19-2012, 07:43 AM
  #45
Davidka's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Yeti AS3
The Flotek works awesome outside.
No short course body works well, anywhere. There's just bad, and less bad.
Ifmar studs huh? Sounds like a Jcon Flip-out might wear better (more knobs, less void). Anybody try anything with smaller knobs, like a holeshot, x2000 or DD?
I didn't realize you guys ran 1/10 outside down there. Might have to make the trip. Is 1/8 electric run on the same days or do those run with the nitros?
Davidka is offline
