St. Charles HobbyTown USA 2012 Racing Season
#62
Kufman, if you're gonna buy a new esc anyway and you can swing it, I'd suggest spending a little more money on a programmable/updateable esc like the RS that has a "stock/blinky" profile. That way you can run in a stock-type class now and then you can change over to a different class if you choose to do so without having to shell out more money for a new esc again later. Having options is always a good thing!
You can spend a little more now or spend a lot more later. Just my 2¢.
#63
#64
#65
As sad and true as your statement is now and perhaps in the near future, there's no saying boost won't come back later.
Well, if he should ever decide to run in a modified class, that option is still there.
#66
I have 1 RS, glad I have it, with economics of my new house to fix up it makes more sense to have 1 $50 ESC than 1 $160. For $160 I would rather have a motor, ESC and tires or body.
Do I love the laptop controllers, sure I have a Tekin and Hobbywing. Boost is disappearing, although some places still allow it and I do run it. Although I would rather support non-boosted classes, to keep it alive.
#68
Truth be told, boost racing should die and never come back. They also need to make some sort of locked timing motor to go with it. As it stand right now, you can crank the timing on the motor and still burn stuff up pretty easily. This was evident at the last big Leisure hours race where all the fast guys in 17.5 were replacing rotors every couple of runs. I would like to see a 10 degree locked, 13.5 motor to go along with blinky timing (which is a engineering oxymoron, but for the sake of this argument we will believe it actually can happen).
I am not against variable timing in the way that Castle and Tekin use it to increase efficiency and also by not using the sensors after start up. These two ideas make sense since the actually motor timing can not be accurately measured by the sensors as RPM and motor loading increase.
#69
If the class changes back at some point, I have 2 other controllers that can handle it, they just happen to be in other cars that I want to leave them in. I was just trying to figure out how cheaply I could run a class this summer. The only real thing I need is a motor and a couple of pinions. I have a spec sensored controller, but it doesn't have lipo cutoff. I ran it for a couple years that way. I just had to be careful when it came to play time after the races that I didn't run the battery too far down.
Boosted controllers are fun and have not fried an rotor yet. Bigger races with open ESC rules and budgets usually I don't enjoy unless they are speced, like the Tamiya series or just plain local racing. Although outside local tracks usually a well setup blinky can beat a boosted car. Personally I think the 17.5 with locked timing is the way to go. As far as the timing probably would guess the 20s. Going back to 13.5 might be difficult being that motor is not engraved as stock like 17.5 is. Plus you deal with comparisons and people not wanting to switch. I think Trinity has come out with one but has not really taken off. Having adjustable BL is not really terrible although if you go past the timing tape you enter amp draw of 2amps and up which is a good way to fry things.
If you are looking for a good class to try, VTA seems to be set in stone. The tires last fairly long are one set and cheap, motor is 1 spec, escs are limited and bodies are old school which is different. Many of the tracks in the area do run VTA if they run in stock, they can be fairly competitive.
#70
I thought about VTA, but I have tons of sedan tires laying around so stock sedan really is the cheapest way for me to go.
A-ko, we will have to have you and the family over after we move into our new house. There is a pond that we can run boats in and a big back yard to run cars in. We can have a gluten free cookout!!
#73
so, what classes do the regulars plan on running?
Traxxas Rally?
stock SCT?
4x4 or mod SCT?
VTA or touring car?
Tamiya mini?
I want to run two classes this year and, if there is only one heat of touring car and no tamiya mini, I want to have a vehcile ready for a 2nd class.
Traxxas Rally?
stock SCT?
4x4 or mod SCT?
VTA or touring car?
Tamiya mini?
#74
Traxxas Rally?
stock SCT?
4x4 or mod SCT?
VTA or touring car?
Tamiya mini?
Traxxas Rally?
stock SCT?
4x4 or mod SCT?
VTA or touring car?
Tamiya mini?
#75
what are the rules for your traxxas rally class?
